Who's running Ferrea hollow stemmed exhaust valves? F2042P
Who is running the hollow stemmed valves from Ferrea? If so how's your experience been with them?
Thanks! Joshua Edit: If you are, please leave info about your setup: Guides Cam Springs Red line limit? Valves Other mods Thanks! |
:lurk:
Does anyone have the part number?
I will be installing it later this year
F2042P. Thats the one I've been looking at.
-Joshua |
Evil427 runs it. As does NavyAirTraffic.
A few others on the Registry listing run it as well. You might try contacting them. The people at American Heritage may be able to give you some more information on it as well, they offer it in one of their head packages. |
Originally Posted by '06 Quicksilver Z06
(Post 1586749180)
Thanks for the info!
Can you confirm that they are one piece? Also what springs are you running with them? I was thinking Katech torquer cam with the PSI Springs that came with the cam. Thanks! Joshua |
Originally Posted by vertC6
(Post 1586749060)
A set can be had for around $275.00 shipped Sorry, didn't see that post just above mine. |
Just picked my heads up an hour ago. Put ferrera hollow stems in them, install tomorrow.
I have them in mine
I have had them in the car about 6-7 months. About 85 grams.
Originally Posted by fendersceptre
(Post 1586749422)
Thanks for the info! Can you confirm that they are one piece? [...]
(Post 1586749422)
Like Quick stated, I run them. Best thing to do is contact Kohle at American Heritage, very knowledgable and generous with his time.
However the real reason I chose the F2042P's is because of what Richard (WCCH) said about the sodium valves on a different forum. Good luck! We have definitely seen excessive wear in some LS7 exhaust guides. Mostly coming from engines with over 30k on the clock. We have seen some heads show inconsistent wear requiring only one or two guides needing replacement. It appears that the sodium exhaut valves are transmitting an excessive amount of heat from the stem to the guide. In some cases the oil is BBQ'd in the guide and the lack of lubrication and cooling from the oil causes the excessive wear (mostly in the lower half of the exhaut guide). We've measured some guides as having over .004" of wear in the lower 1" of exhaust guide length. Porsche 911's suffer the same type of related guide wear on the exhaust side. The next item to note regarding the sodium exhaust valves relates to the wall thickness of the sodium exhaust valve stem. It's only .040" thick and makes for a fragile exhaust valve. GM uses a good quality steel material but the design spec. renders the valves brittle at the neck. Hence the reason we choose the replace the factory units with stainless or inconel. The exhaust valves we use are manufactured with a .001" oversized stem size which allows us to hone the exhaust guides and remove most or all of the taper in the bore. In cases with excessive wear we replace the guides with bronze. |
Hi Navy,
Thanks for the info! Are you limiting your red line at all? Also what springs and cam are you running? Thanks! Joshua
Originally Posted by NavyAirTraffic
(Post 1586750513)
However the real reason I chose the F2042P's is because of what Richard (WCCH) said about the sodium valves on a different forum. Good luck! |
:lurk:
QUOTE:
We have definitely seen excessive wear in some LS7 exhaust guides. Mostly coming from engines with over 30k on the clock. We have seen some heads show inconsistent wear requiring only one or two guides needing replacement. It appears that the sodium exhaut valves are transmitting an excessive amount of heat from the stem to the guide. In some cases the oil is BBQ'd in the guide and the lack of lubrication and cooling from the oil causes the excessive wear (mostly in the lower half of the exhaut guide). We've measured some guides as having over .004" of wear in the lower 1" of exhaust guide length. Porsche 911's suffer the same type of related guide wear on the exhaust side. The next item to note regarding the sodium exhaust valves relates to the wall thickness of the sodium exhaust valve stem. It's only .040" thick and makes for a fragile exhaust valve. GM uses a good quality steel material but the design spec. renders the valves brittle at the neck. Hence the reason we choose the replace the factory units with stainless or inconel. The exhaust valves we use are manufactured with a .001" oversized stem size which allows us to hone the exhaust guides and remove most or all of the taper in the bore. In cases with excessive wear we replace the guides with bronze. :crazy: :crazy2: :iagree: :flag: :lol: Man, i don't know how much better some people on here need it explained to them!? :crazy: |
I'd like to see these valves on the spintron machine:
Torquer cam/psi beehive springs/ferrea hollow SS valves. My guess, they would show stability up to 7,100. But I'd like to see the test run |
Yeah that made a lot or sense till people started realizing that it valve guide issues aren't isolated to just exhuast sides.
I think now the consensus is it's a valve seat machining error and there aren't really any issues with the valves. That being said, a two piece valve won't stay together after abuse or machining errors as well as a once piece.. |
Originally Posted by ramairws6
(Post 1586754474)
[...] It appears that the sodium exhaut valves are transmitting an excessive amount of heat from the stem to the guide. [...]
(Post 1586754474)
By the way, folks, ramair's post was plagiarized, verbatim, from a four-year-old post by someone else on another forum: http://ls1tech.com/forums/13450863-post12.html . |
I wouldn't have known because he's on my ignore list.
