1982 differential leak
I found a trail of oil and finally a big puddle of gear oil under my differential after parking the car in the garage. Near as I can tell, all the seals are intact. I had driven the car for about 10 miles before I parked it in the garage. No strange noises coming from the diff. If not for seeing the trail of oil leading into the garage under the car I wouldn't have known anything happened. Ideas anyone?
Limited number of places for oil to be coming from- the side axle seals, pinion seal, and the rear cover. After that, the fill plug. If those are all good, then it's likely to get expensive. A hole in the case/cover. If it was overfilled, it might blow oil out the vent. Thinking about that, is the vent in place or missing?
Clean everything up, fill the diff with proper fluid then take it for a short ride. After that you should be able to see where it's coming from. Good luck :thumbs:
I know gear oil has that distinct stink... That said, are you sure its gear oil? I had a leaking trans that somehow migrated onto my rear diff area and dripped. I had it parked on a slight incline and that made it worse. My 82 has the seeping seals on the rear diff, not enough to drip but stays wet. I did the above; clean, fill, inspect to narrow it down. Saving for a rebuild on it now.
I'll be interested in hearing how this turns out. Gear oil is pretty thick and normally you will just find it seeping and you will only get a few drops after you park it. I'm having a hard time imagining a "trail" of gear oil. I'd think it would only be a spot every 20 ft or so for a pretty bad leak.
82 diff leak
Originally Posted by Arkyvette
(Post 1586458919)
kennycorvette
Originally Posted by my 76 ray
(Post 1586459193)
