Try asking for someone with a tech II to check it out. The remote control receiver may have died and does not read the FOB. Is the theft light on?
Fuse Box
Originally Posted by 615C6
(Post 1586459616)
Battery passed load test.
you may have a bad ground at the fuse box. I have a 2005 vette and my fuse box became loose and ungrounded, my would not start. hope this helps. enzo |
Thanks guys. BCM didn't make it here yet. Should be in tomorrow im guessing. No security light or anything. Instrument cluster is completely dead. Only thing that works on the car is the under hood light and headlight and taillights when I switch them to on. I spoke with a tech that has a tech2 scan tool and I will get him to re program the BCM once I install it. Fuse box is tight and all grounds are good and clean. The starter wire is good. Wiring harness is good also. No blown fuses or relays. New key fob battery and car battery. Hopefully once I install the new BCM at least my cluster should come back and ask for key FOB.
Installed new BCM and no change. The 4 post that secure the fuse box are snug. Is that the post that ground the fuse box? If so im not getting continuity to ground on either one of those 4 post.
Just realized when I connect my battery post to the battery I can hear something wine in my dash. Almost like the sound of a fuel pump priming. My best guess is nav/radio. My power seats will work but my door locks and windows don't. Also my emergency flashers work but wont show in my cluster because my cluster is still dead. With my battery connected I checked for voltage at the PCM 15A fuse on BCM and im not getting voltage there. Not sure if I should be getting it there and if so when? I am getting battery voltage to my BCM from the red with black stripe wire and also the red with white stripe.
Your mention of the board under the passenger side reminded me of this post.. I would check it out:
http://forums.corvetteforum.com/c6-c...g-gremlin.html |
2 Attachment(s)
Did the BCM wiggle test with no change. I double checked my wiring harness and did find this. Which I thought for sure would fix my problem. I soldered and heat shrink these two wires but still nothing. Does anyone know if a bad key fob or security system would cause these symptoms? Any last resorts before I have to tow this to the dealership?
(Post 1586513367)
Keep us updated, I'm actually really interested now in finding out what was up with it.
(Post 1586730817)
Wanted to give y'all an update. The car is at the dealership getting checked out. The advisor called me letting me know they can't communicate with any of the modules. There going to check each module.
Good luck!! |
Originally Posted by DillingerRadio
(Post 1586730933)
Yeah I'm hope it's just the BCM. I'll def keep y'all updated.
(Post 1586739969)
I’m sorry that I did not see this earlier, but we’re around as well to answer any questions you may have. Let me know how it goes. Have a good day! Jennie R. Chevrolet Customer Care |
Having a similar issue. Definitely interested as to what is it.
end of the story, is it running?
No. Dealer still hasn't found the problem.
(Post 1586801361)
Originally Posted by silverGS
(Post 1586881620)
anyupdates?
mines did the same thing and my car was a bad pcm have they checked your pcm 4 weeks with no car and they still dont know what is going on.
(Post 1586941481)
