Picked up some pieces today
Heads weren't in, just as well, only 1 head gasket showed up.
Did it ever feel good to hold those bits and pieces tho, feels real now!:rock: Thot I'd throw this in for a laugh... http://i1358.photobucket.com/albums/...psda8c3282.jpg Been super busy lately, never gonna find time to gear this motor up, weathers been miserable, not even getting any ride time |
Pro Filer heads showed up today... Can't get a pic up yet, but I'm so stoked. First time in about 10 yrs I just boughtsomethin "just because"
Ok, so step 1 will be install newcam and gear... Retro fit roller, what do I need to watch for, how do I get started, I'm so psyched, :rock: |
Originally Posted by vettezobsezzed
(Post 1587205203)
Update
Just ordered obx sidepipes of eBay. Pretty sure I've got a set of proper wheels lined up Like to get a set of mirrored tops, in the works Gonna be a hole new car next spring if. It all works out Winters coming fast -1*c here this morning! Sooner it starts, the more time I'll have to execute my big plans... |
Originally Posted by 76strokervette
(Post 1586437190)
I agree 100%. I have a dart shp 400 with 72cc pro-filer 210 heads and
cometic .027 mls gaskets.The .027 gaskets are the thinnest I could find. |
The pro-filer heads calls for a fel pro 1014 head gasket per pro-filer.This gasket has 4.200 bore to un-shroud the combustion chamber.If you have found a thinner gasket please post it.The only gasket I have seen thinner than the cometic .027 is a copper one.
Couldn't get a cometic at the time, got these, what you guys think?
Special thanks
Thanks to big Eddie for setting me up with glass t tops
Thanks to nomocrap for setting me up with original wheels :rock: can't wait to roll out of the garage next spring... Just a few more finishing touches on my garage restoration, & I can move fwd on this vette project |
I'm a believer in compression and your afr heads are aluminum so they are more forgiving than cast iron. At worst case scenario you'll have to add a little octane boost if you get a crappy tank of gas. It happens to me with my SS Silverado with an LQ9
I have a 406 on the engine stand and I did use ARP stud for the 2 bolt mains. Your engine is very strong but I would stay away from holding it over 6500rpm for long periods of time. Do you have a high volume oil pump? |
Do believe its a stock oil pump, am building off a used shortblock I had built years ago. It was awesome at the time, but destroyed truck it was in. Resurrecting it again with some serious upgrades, hopefully my vette doesn't have the same fate...
I backed out on AFR heads, went with 70cc profilers. Still be running high comp, but should be ok. |
Think I'm in trouble!
Need help, somewhere along the way I bought a cam that I thought was close to what we'd discussed. It's a lunati #20120712 282/290 adv. 231/239 @ 0.050. 0.535/0.550 w/1.5 rocker. Says intake closing point is 41.5 ABDC. My math says this puts me @ about 9.4DCR. If so, it's no good, right? I believe I need to be mid 60's ABDC, right? Help! Do I need a different cam. Where did I go wrong?
(Post 1588109919)
Go here and put in your specs minus the intake closing point and it will give you the intake closing. http://www.jeepstrokers.com/calculator/ |
Originally Posted by REELAV8R
(Post 1588111763)
I had this same issue with Lunati cam specs. They list all the open/close points @ .050" lift. I don't remember the conversion right now Mako63 has it posted. Try a search.
Go here and put in your specs minus the intake closing point and it will give you the intake closing. http://www.jeepstrokers.com/calculator/ https://www.corvetteforum.com/forums...lculation.html Just reposted this thread. |
Awesome
Ok, so I reran it in jeep strokers, after I used mako's math (which I'd already studied). All good now, closing pt of 67*. DCR @ 8.13.
I was under the impression that the cam card was the "official document" so I reran it in the stroker calc and came out @ 9.54 DCR, was almost sick in my stomach, since I'd already installed the cam. Ok, so I feel quite relieved now. Gasket kit is in the mail, should have base pan and timing cover sealed up this week. Pushrod checker is on its way too. Will be needing some guidance when I tackle this part, just have never done it. So, leave the cam straight up and seal it up.? I trust you fellas calculations. Just want to make sure I'm not "lost in the woods" here.:canadaflag: |
(Post 1588113146)
It is understanding, that u want to keep below 8.5 dcr w/aluminum heads to run pump fuel
Did you check the intake closing point with a degree wheel?
Haven't got that far yet...
