Originally Posted by Mr.Nubain
(Post 1586391872)
The initial numbers seem very high imo. Even though your not happy with what the numbers say, take a look at what other guys get with the same configuration and it seems spot on. Also, see what it can do on the track. I'm sure you'll be happier then.
Originally Posted by saplumr
(Post 1586391481)
Curious what the car made on initial pre-mod dyno. It sounds like you somehow picked up 120 hp from your first mods.
Originally Posted by D.Guerra
(Post 1586392268)
Shawn is a good guy. He's always done my tunes, matter of fact he'll be doing mine when these LTs and complete exhaust gets installed.
Also why is it so far fetched to believe my car made good numbers?
I did a cam and LS3 top end and picked up 100 RWHP using a FAST, already had headers, so I have to agree that the first numbers appear high.
Best thing would be (or would have been) to have some track times, make your changes and hit the track again. Dynos mess up. Look at your correction factors for each day. If the weather station values are messed up in any way, it can throw the numbers off on either of the days you dyno'd.
original numbers great
Originally Posted by brightc6
(Post 1586386213)
Like the title reads, I have a cam only ls2 2007 corvette. The car made 441/446 before i put the FAST 102 intake the car. First pull untuned car picked up 1 hp, after tuner messed with it for a while it got to 5 hp. I read soooooo much that FAST 102 is a must have for LS2 cars that i bought into the hype and very disapointed.
Same dyno, same tuner, 30 days apart, no other changes where made. Car has kooks 1 7/8 headers z06 mufflers open baffle cam 223/235 615 621 113 vararam 25% underdrive pulley port TB STOCK unported ls2 intake made 441/446 with that setup added fast 102 (unported) w/ vmax ring made 446/447 any ideas? |
stock converter...I drive the car on trips and didn't want to worry about it have any tranny heating issues.
as far as track times go....I did go to 1000ft track while I was in Arkansas so really hard to just times off of that. car ran 9.70 at 111mpn with 1.95 60ft. Keep in mind that is still 320 ft short of a full 1/4 so that means car should be solid 11 second 1/4 car on street tires. |
Is your v max ring on both before and after? also it has to be a tuning or wrong correction factor, the proof is in the pudding, the fast intake in 90 92 102 has shown great gains in the LS2 in all cases I have seen. I myself have seen no less then 30 tq hp over the whole entire rpm band with just bolt/ons, so if you haven't and nothing else has changed, the tuner is great, then maybe a bad injector, I'm just guessing. but your tuner should know, I just ask you this. do you actually think with all the testimony and proven dyno and track times that you have the only fast that shows such insignificant gains, maybe a defect, send it back and get another one or have the tune figure it out because it makes no sense, was the converter locked and in the same gear both pulls
yes asked those same questions...converter locked both pulls, same gear both pulls, both numbers are corrected. trust me I have read all the threads about how great the fast intake, hints why I spent the 800 bucks for one. As for it being defective that is why the tuner wants to take it off and check everything out in the intake.
I doubt it is a bad injector, car has no miss and runs very smooth. |
I have seen a couple run very smooth, and the dyno was lower then expected they found a bad injector, i have seen broken valve spring with no signs of a miss just a lot slower et :thumbs:
What the hell is a V Max ring?
And I'll never understand why people will bolt on all these parts to a set of poor flowing stock cathedral port 243 heads and expect to gain a million hp... The intake valve (and those stock LS exhaust ports) are always the biggest impediment to airflow. Buy some AFR's or TrickFlow 225 heads and see your numbers really climb! |
Originally Posted by FederalPerformance
(Post 1586396923)
(Post 1586396923)
what tire
(Post 1586394654)
When I upgraded my LS2 I opted for a CNC ported set of Pro Comp heads. Comparing them to the stock heads the intake runners were notably bigger. I should have taken some side by side pics.
My thoughts on intakes is that they should match the heads. Runner openings and sizes need to be the same especially at the surfaces where they meet. And in this case the differences were pretty significant. I thought about ordering a Fast intake, but then what head are they sized for. Are they designed to fit a stock head with those small runners? And spend in excess of a thousand bucks to pick up maybe 15 to 20 horsepower at the most? I decided to pick up a second stock intake for a couple of hundred bucks. I then made a pattern from my CNC ported heads and securely mounted to the head. I then mounted the intake on it and tightened it up just enough to insure it was centered. Then I pulled it off transferring the pattern to the intake. Then I spray painted it white. The difference in the size of the runners on the new CNC head meant that the intake needed to be opened up right to the limit of what it allowed. Porting it was real easy. Plastic grinds away a lot easier than steel or Aluminum heads. Sanding rolls were all I needed for my die grinder. I continued the pattern size as far up into the intake as possible and smoothed out a lot of rough casting spots. I was real happy with it and have a port matched intake and that alone probably picked up as much or more power than going to a Fast. Just thought I'd share that with you guys, for whatever it's worth. |
(Post 1586392632)
My advice is let the car be, and don't chase a dyno number. |
(Post 1586396923)
(Post 1586396923)
And I'll never understand why people will bolt on all these parts to a set of poor flowing stock cathedral port 243 heads and expect to gain a million hp... The intake valve (and those stock LS exhaust ports) are always the biggest impediment to airflow. Buy some AFR's or TrickFlow 225 heads and see your numbers really climb! http://i49.photobucket.com/albums/f2...headers001.jpg |
Originally Posted by Danny Richie
(Post 1586399332)
My thoughts on intakes is that they should match the heads. Runner openings and sizes need to be the same especially at the surfaces where they meet. And in this case the differences were pretty significant. I thought about ordering a Fast intake, but then what head are they sized for. Are they designed to fit a stock head with those small runners? And spend in excess of a thousand bucks to pick up maybe 15 to 20 horsepower at the most? I decided to pick up a second stock intake for a couple of hundred bucks. I then made a pattern from my CNC ported heads and securely mounted to the head. I then mounted the intake on it and tightened it up just enough to insure it was centered. Then I pulled it off transferring the pattern to the intake. Then I spray painted it white. The difference in the size of the runners on the new CNC head meant that the intake needed to be opened up right to the limit of what it allowed. Porting it was real easy. Plastic grinds away a lot easier than steel or Aluminum heads. Sanding rolls were all I needed for my die grinder. I continued the pattern size as far up into the intake as possible and smoothed out a lot of rough casting spots. I was real happy with it and have a port matched intake and that alone probably picked up as much or more power than going to a Fast. Just thought I'd share that with you guys, for whatever it's worth. And what gains did you see from your PRO Comp heads??? |
Originally Posted by 96mogt
(Post 1586400093)
I did a mini review of the heads. If you are interested I'll find a link to it. I haven't dyno'ed it, but will be taking it to the strip on Saturday. |
