you have to be just messing with me. :lol: The only thing I know for certain is that you are the one who does not have the answer sir. I sure am glad that my car has a working fuel system.
Good luck maybe tomorrow you will wake up on the correct side of the bed. :thumbs: :cheers: no seriously give us detail man!! I really want to help or find someone who can. :cheers: |
Originally Posted by MVP'S ZO6
(Post 1586177516)
Good luck maybe tomorrow you will wake up on the correct side of the bed. :thumbs: :cheers: |
Originally Posted by Corvette0096
(Post 1586177523)
You have any pictures of your fuel system.. Or did you pay a shop?:cheers:
can you post exactly what your looking for maybe im reading your thread wrong but your concerned with the level of the pump in relation to the fuel level? They did move my regulator though. so that's about the only modification they did to my fuel system. |
heres some A&A fuel systems too look at http://www.aacorvette.com/supercharg...9oqgg3vefskvl7
(Post 1586177537)
my fuel system was installed before my car went to the shop. however my car has two intank pumps. its slightly different than yours.
(Post 1586177564)
I don't have the Teflon lines or the elbows yet. So I was going to check out pictures of different installs. I want the pump to be low enough so I will not induce air into the fuel system. It's gravity feed. I am going to order my parts from Pegasus racing and wanted to get a idea on what to buy. I know I need one of these to tap into the factory lines Aeromotive 15120..
unless your trying to install the pump on the roof and run your car danm dear out of fuel, I dont think your going to run into cavitation issues. |
Originally Posted by a/c man
(Post 1586177554)
(Post 1586177571)
which pump do you have the bosch or aeromotive 1000A or what ever that big ass pump is? the pump is check valved right?
(Post 1586177554)
andy has some good pics. hahaha. |
(Post 1586177592)
044 with a high flow check valve.
now on to fittings? |
(Post 1586177599)
good so, if you mount the pump at tank level or slightly below, i.e. like andy's kit shows in the left fender well. you should not have any cavitation issues.
You mean to say 1/4 panel? Fender is up front of the car.
(Post 1586177613)
Yah help a brother out.
if so than what else are you trying to accomplish? |
[QUOTE=MVP'S ZO6;1586177621]so let me ask this? your system did not come with any fittings?
if so than what else are you trying to accomplish? I had a pump already so I only bought the bulk head. :yesnod: |
[QUOTE=Corvette0096;1586177632]
(Post 1586177621)
if so than what else are you trying to accomplish? I had a pump already so I only bought the bulk head. :yesnod: ahhh i see so you need the bulk head fitting? what are they -8AN I think? http://www.jdaent.com/high-flow-bulkhead-adapter.html |
This is the bulkhead mine takes from ECS.
http://home.comcast.net/~vadian//pwp...l%20Spacer.JPG |
(Post 1586177645)
http://home.comcast.net/~vadian//pwp...l%20Spacer.JPG looks like a -8 too me. |
(Post 1586177649)
ok so you need the fitting that comes off it? explain to me brotha!!
what year is your ride?
Originally Posted by mvp's zo6
(Post 1586177665)
