Originally Posted by Chuck Mahnke
(Post 1587675552)
Running at full power (both motors on) the MB draws 18 Amps and therefore will trip 15 Amp circuit breakers. It requires at least a 20 Amp circuit. Many new homes will have at least one 20 Amp outlet in the garage but in my case with an older home, I added a 20 Amp breaker to my electrical panel and ran 12 gauge cable to a new outlet in the garage. A very simple project for anyone with basic knowledge of electrical wiring. It took me less than an hour and minimal materials expense. Now I also have additional capacity for power tools in the garage.
I bought a 50 ft ( 20 amp) extension cord to plug into the wall and then out to the drive way for the Master Blaster. The cord is about a half inch diameter ( 10 ga I think) and weighs a ton.. Haven't tripped the breaker ever. |
Originally Posted by WKMCD
(Post 1586096864)
I dry mine ONLY with a chamois made from the belly hide of unicorns. :thumbs:
Originally Posted by Nicky43
(Post 1586328386)
Excellent Idea. Where did you get the Hose extensions? I bought a new Master Blaster when I got my new Black C7 but find it too slow to use. It seems to just push the water around the car from one spot to another. It is great for getting water out of all the little nooks and cracks but it takes way too long to dry the car with it. I have switched to super high quality micro fiber towels for drying and can dry the whole car in three minutes. I can't do it in less than 30 minutes with the master blaster and it's still not completely dry when I use that extremely loud Master Blaster.
What might I be doing wrong? What tip do you use? |
Mine is a DD, so I try and convince myself not to be too anal retentive about it. I've found that 90 - 100 mph down the road after washing gives a pretty good blow drying. :woohoo: A microfiber towel does the rest.
Originally Posted by Strake
(Post 1587675594)
:iagree::iagree::iagree: I had a 20 amp outlet put in our garage when we had the house built. I also use it for my air compressor.
I had a master blaster but it was just too much effort to lug around and it kept shutting off because the power in my garage isn't strong enough, so now I just use a Cobra Supreme Guzzler to go over my car in 2 minutes, then I blow the cracks and crevices with the Air Force Blaster Sidekick which is much more convenient then I do a final pass over the car with Meguiars Synthetic Spray Wax.
(Post 1586096864)
I spray detailing spray on the drying car and dry it using a micro fiber and the mix of water and detain spray. Works well. :iagree: |
Been using an electric leaf blower to dry my cars for about the past 12 years.
