Blow dry your C7
Just picked up my TR-Z51 last week,when it comes time for the first bath.It will be done by me by hand. Picked up a good idea on line how to dry your car.They said use a electric grass blower highest blowing power goes for about 100 dollars,you know the stores.DO NOT USE A GAS BLOWER.I believe this is a very good idea,will get those places a towel never gets.R
Originally Posted by rsl2715
(Post 1586096688)
Heats and filters the air too. http://www.southerncarparts.com/corv...er-p-4006.html :cheers: |
Make sure you get the blowers with an intake filter, otherwise you blow stuff in the air right into your paint. I use a black and decker cordless . Final wipe is with a waffle weave towel, straight from dryer, made for drying.never scratched in 10 years.
(Post 1586096688)
I have a Master Blaster and it works very well :thumbs:
(Post 1586096688)
I ONLY dry my cars with an electric leaf blower. The more you put towels on the paint the more micro/fine swirls and scratches you will introduce into the clear coat. Especially bad in darker color cars. Also be sure to pre soak using a foam gun and then wash with the 2 bucket method. If and when you use towels, always use clean and tested ones, I always keep a few new computer CD's lying in my garage for the CD test. Mist the CD with detail spray and wipe with the towel. If the towel scratches the surface of the CD it does not get used on the car and is then relegated to interior and under hood clean up. I personally keep about 200 micro fiber towels on hand and store in plastic totes labeled clean and dirty. Wash with only liquid laundry soap and air dry - never put in the dryer with fabric softener. Good luck with the new Stingray!
Gas can throw oil and film onto the paint.
I use an Air Shammey that I got for my motorcycles. Works great and it's quite a bit cheaper than some of the others. http://www.airshammy.com/
I ONLY dry my cars with an electric leaf blower. The more you put towels on the paint the more micro/fine swirls and scratches you will introduce into the clear coat. Especially bad in darker color cars. Also be sure to pre soak using a foam gun and then wash with the 2 bucket method. If and when you use towels, always use clean and tested ones, I always keep a few new computer CD's lying in my garage for the CD test. Mist the CD with detail spray and wipe with the towel. If the towel scratches the surface of the CD it does not get used on the car and is then relegated to interior and under hood clean up. I personally keep about 200 micro fiber towels on hand and store in plastic totes labeled clean and dirty. Wash with only liquid laundry soap and air dry - never put in the dryer with fabric softener. Good luck with the new Stingray! |
I dry mine ONLY with a chamois made from the belly hide of unicorns. :thumbs:
I spray detailing spray on the drying car and dry it using a micro fiber and the mix of water and detain spray. Works well. |
Originally Posted by H2LS3
(Post 1586096738)
Electric leaf blowers work good, but if you want to take it a step further check out the master blaster.
I've been using an electric Toro blower/vac for maybe 25-30 years. Great for an initial (you want to leave some spotlets on the windows and body to wipe off any spotting or streaking) drying and a final at the door handles, license plates, mirrors, or any place that water migrates to before it drys. Absolutely great for wheels. Corvette owners have been doing this for years since most of us are so anal!
(Post 1586096738)
Master Blaster. I swear by it.
The Electrolux lives on! :rock: |
I use my Echo gas blower and never had a problem and no need to worry about an electrical cord. I hold the tip with one hand and the other the blower. In one minute I get the wheels, mirrors, taillights and most of the water off the car then finish with Griot's yellow drying towel(they are great).
Originally Posted by Glen e
(Post 1586096753)
blow dry
Originally Posted by c6miller
(Post 1586098260)
(Post 1586098260)
The exact same thing I do. I leave a little water on so that the towel does not touch the car dry. |
Originally Posted by MikeK
(Post 1586097305)
...since most of us are so anal!
