2015 ZO6 Corvette....
1 Attachment(s)
In case you have not yet seen the specs on the upcoming 2015 Corvette ZO6, take a look at this.
FWIW |
Originally Posted by pmihaltian
(Post 1585995618)
FWIW |
Hopefully with the heat soak it still is more powerful than a C6 Z
Nice! Thanks, OP. :thumbs:
Nice spec list. Did I miss the anticipated weight? Didn't see it anywhere.
Originally Posted by Despicable Z
(Post 1585997025)
Originally Posted by MudZ06
(Post 1585997039)
in a Q&A GM said heavier than the base C7.
My gut said it would be heavier than the C6Z but I was thinking mid 3200s. I guess we'll have to wait and see what comes out. Curious what the final HP numbers will be too, my guess is 640ish. |
What if there was a C7 section...... ?
Originally Posted by erichg1000
(Post 1585996517)
(Post 1585995618)
FWIW |
Awesome car but also unfortunately still over designed and busy. A monster for sure but hoping a refresh comes sooner than later.
This option on the C7R should be available on the Z as well.
"short/long arm (SLA) double wishbone, fabricated steel upper and lower control arms, coil-over-adjustable shock absorbers" |
Originally Posted by ibleedgreen
(Post 1585998486)
Originally Posted by Hirohawa
(Post 1585998345)
(Post 1585995618)
FWIW |
Originally Posted by Z06Ronald
(Post 1586000189)
Seems like overkill for the street to me, unless you anticipate to take speed bumps, pot holes and side walks at 100+ mph. :willy:
Either way these cars work 10 times better with coilovers! Street or track....:thumbs: |
(Post 1586008132)
Why would it have to be for the street? Just an option.
Either way these cars work 10 times better with coilovers! Street or track....:thumbs: I have coil overs myself (Moton). :thumbs: |
(Post 1586008431)
Specifically I meant the fabricated steel A-arms, but I was a little ambiguous, I have to admit.
holding out for the L88. The z06 is weak in my humble opinion.
LOL |
Really impressive specs for the car. Have to wonder just how much the hp/torque mbers will change between now and when it hits the market.
