Oil dipstick install
Installed ls7 manifolds on my 05 Corvette and have been unable to reinstall the oil dipstick what am I doing wrong?
Originally Posted by joshz06
(Post 1585832223)
Had to have my wife spend 30 seconds in the garage on this... After I spent 10 minutes unsuccessfully trying to re install on my own. |
Put all the bolts in the manifold but leave the manifold loose.
Insert the tube into the pan, you will probably have to wiggle/bend/finesse the tube a bit to get it to fit. If I remember it has to be bent forward slightly to fit, but it will go in. Once you have the tube installed in the pan tighten down the manifold and then finesse the tube to put the bolt in. It's a one person job ...... |
