Dumb question but I have to ask. You aren't leaving the choke on too long are you? Just wondering if that could be fouling the plugs. I'd pull them again to see if they're sooty.
Originally Posted by Gary's '66
(Post 1585737075)
Originally Posted by jim lockwood
(Post 1585737149)
This is a reasonable question. My own '54 demands that I push the choke in immediately after it starts.
as soon as it cools off, i'll take the plugs out and clean them off again, i'll let you know what each plug looks like. i sure appreciate all the help.
i'm thinking that the car just sat for too long that the rings are seated anymore?
redo, i can't type i guess today
i think the car just sat for too long and the rings haven't seated correctly, and i am and have not gotten the car up to speed, and i keep loading it up? i'm just guessing, but i think when i get the car running i'm so afraid of revving it up that i don't so i just keep it like at 1500 rpm, which i'm probably the problem.??? |
Originally Posted by Tina Marie
(Post 1585737302)
ok so here is my findings for the plugs.
1. sooty 2. not so bad 3. sooty 4. sooty 5. perfect 6. perfect so Gary, if the fuel system is varnished and would need cleaning….. how would a little bitty girl go about doing this task, is this something i can do in my garage or i have to have it towed to a mechanic. details details please…. thank you so much! |
i just noticed the time from when i last posted to the time that i got done with taking the plugs out, cleaning them, and putting them back in, not bad for a chickie!
Nope, not bad at all. Yeah, if you're not real sure about how to do it I'd bring it in to someone. The carbs will need to be soaked and cleaned, fuel lines and gas tank cleaned. Run another post to find a mechanic in your area if you don't know someone. Did you have a chance to check the filter yet?
These are just a view more pics
2 Attachment(s)
Here is a pic of me? oh well i guess i do look 51?
Here is a pic of me sitting in the vet in Arizona |
Very nice, both of you look quite well preserved.
(Post 1585737556)
fuel filter looks nice and clean. i was going to take the hose clamp off the one that is pretty close to carb 1, but ended up not doing that, i was going to take the plugs out and kick it with my attached starter button gizmo to see if gas was even coming out, but really don't think that was necessary because i can get it to run. just this morning i got it going, for quite a while, just kept it not above 2000 rpm. but i'm glad to hear that it isn't going to be the rings, and i hope it isn't anything to do with the engine at all, dad said that he had it rebuilt about 10 years ago. he's going crazy that i'm having all of these problems with it and he can't be here to work on it with me. i told him to not worry about it, i can do just about anything i set my mind to. however i don't want to do anything with the carbs like taking them off, it really looks like that would be over my head for sure. and i do know where the gas tank is but draining it looks like a tuff one. i did order a new tri carb linkage bracket from corvette gal it should be here next friday, my dad had the bracket between 2 and 3 break on him a while back and he welded it the best he could which it's fine not anything to do with this issue, but i am sure i can get the old one off and get the new one on after looking at it for a bit, i'll probably have an issue with the spring as it will be hard for me as i'm just not that strong in the upper body. anyway, that's my story. |
Well good luck and don't be afraid to ask for help. Lots of good people here always willing to help out, especially a pretty lady.
Tina, your '54 is gorgeous. I wish mine looked that nice (it's unrestored).
without the choke it dies, and then when i use the gas peddle it dies for sure. ok so here is my findings for the plugs. 1. sooty 2. not so bad 3. sooty 4. sooty 5. perfect 6. perfect In any event, my take is that it wouldn't hurt to rebuild the carburetors. Rebuild kits include new accelerator pumps and new needle & seats, among other things. It's not a bad job; you can do it yourself if you are just careful and well organized. And besides, you said: i can do just about anything i set my mind to Jim |
(Post 1585737648)
If you wanted to attempt to flush your fuel system yourself, you could:
At this point you have all new fuel in the fuel system, a low-grade flush has been performed, and you've confirmed fresh fuel is coming out of the system I told him to not worry about it, i can do just about anything i set my mind to. If you do the above you'll know that you are getting clean fuel to the carbs, although with usage you may dislodge more gunk from the fuel line and thus you should check the fuel filter from time to time. After sitting that long, I would recommend getting the carburetors rebuilt by a reputable person. If you are inclined, you could remove the carbs yourself and toy with rebuilding them yourself, choosing to give them to a rebuilder if you get uncomfortable once you are elbow-deep in the carbs. Jeff |
If you feel the need to take it to a mechanic, (I didn't say technician) I hope it's one (look for wrinkles and gray hair) that actually knows old cars. Today's tech's only read and associate with digital data. Please use caution, because some people can make things worse and damage parts etc. Since you are in "Big D", some shop or person can be found. We probably have a CF member in "Big D" that knows a person or place. Good luck! :cheers: Dennis
Originally Posted by Bluestripe67
(Post 1585737844)
Carburetor manuals for purchase (download)
http://carburetor-manual.com/advance...ter+YH&x=0&y=0 http://carburetor-manual.com/1953-19...nual-p-96.html |
ok you all are just fantastic!
Gary, Jim, Dennis & Jeff! Wow, i'm getting misty on all your help! never met people that are as great as you all are! So, what i'm going to do is take Jeff's suggestion, going to get my hands dirty on this one, but i'm really not a dumb blonde, and i think i can do it. I'm not in a hurray at all, this was my mothers car, and even if i can't get it to run again, i will keep it forever and ever. But however she is smiling at me on this one, she knows that i can do it. I had a flat bottom jet boat with a 455 olds in it, i had the engine balanced and blue printed back in california, as that is were i am originally from, Northridge CA to be exact. Left after the 7 earthquake which was the Northridge quake, lost my house, lost everything. Moved to Dallas, my parents moved to Lake Havasu City, AZ to retire. Anyway my boat was a real piece of sh&t before i had it rebuilt, but after that i got tired of the points and condenser always going out, so i put in a Mallory electronic ignition, and wow what a difference no more timing no more fuss. It had a Holley 750 double pumper, and i had trouble finding someone who new how to jet them, so i just got a book read a lot and this was way before the internet, anyway, did it myself, and man it was sweet. Just went up to the lake and it took me about 2 hours with a box full of jets to get the right balance, but you know i did it, no one else. So i feel like i can tackle this at least if i get up to my elbows and can't i'm sure i can find someone on here who can help me out. I'm really thinking that if i just took the tops off of the carbs i would see a whole bunch of gunk and find they are just sticking the float isn't working at all in the bowl, i bet. had the same problem with my Holley but took it apart and used mineral sports and cleaned it and it worked just fine after that, and never had another problem. but i do need to get everything out of the fuel system like Jeff said, flush the system etc. One question Jeff, instead of removing the coil wire, couldn't i just take all the plugs out instead, for some reason i feel more comfortable doing it that way instead of just pulling the coil wire? Anyway, your all the best! Tina Marie |
