Brake bias spring
I put the bias spring from DRM in my '85 and I have never really been happy with the front brakes since. I thought it may be a lack of pressure from the master cylinder so I put a reman master on which made it worse. Since then I have also replaced the booster trying to figure out how to get the car to stop right.
Now I am getting ready to do the C5 upgrade on the front so this leads to my question. I have read that the bias spring is a necessity when doing this upgrade so is the bias spring the reason the stock front brakes are not quite adequate? I'm just about ready to order another master cylinder, thinking that maybe I just got a defective one. One other thing, I also installed a vacuum canister just in case the vacuum was not enough, it did no good either. |
Originally Posted by Midnight 85
(Post 1585677450)
Now I am getting ready to do the C5 upgrade on the front so this leads to my question. I have read that the bias spring is a necessity when doing this upgrade so is the bias spring the reason the stock front brakes are not quite adequate? I'm just about ready to order another master cylinder, thinking that maybe I just got a defective one. One other thing, I also installed a vacuum canister just in case the vacuum was not enough, it did no good either. This is one of the "better" reads regarding C5 on early C4 conversions. There's nothing that seems to be overlooked and if your interested in "better" braking it's a very good read. Your car seems ideal for maybe a complete hydraulic change. Maybe? Maybe not? http://members.shaw.ca/corvette.84/C5brakes.html |
Originally Posted by WVZR-1
(Post 1585677609)
Do you know that you have the correct bias spring? There's an ABS and a non ABS. Do you know that you were sent the correct one even if you ordered the correct one? Several years ago there was some debate as to short or long and DRM responded to the thread with a comment like we'll check and I don't remember them returning back to the post. Check with VBP and see what they have to say regarding the length or maybe number of coils or the value of maybe loaded/unloaded.
I just ordered the VB&P spring and there is different springs so I hope this takes care of the problem. The car will stop, even in a close call situation but it just doesn't feel right and since it does not have abs it should lock the fronts up easily, it will not do that.
(Post 1585679057)
(Post 1585679057)
I did a C5 front brake conversion about 5 years ago on my '87 and it was a huge improvement in braking performance. I didn't have that link at the time, but it does have the same information about what I had to do. Right now, I have stock C5 Z06 front pads and Hawk HP+ in back. I also used Earl's stainless lines to replace the original rubber lines. As mentioned, there are different bias springs for ABS and non-ABS cars. I did not change the MC. When you do the C5 upgrade, know that there is no difference between the Z06 caliper and the standard caliper except for the red paint on the Z06 caliper. Also I use standard C5 front rotors; my '87 is for autocross and track days so rotors are just a maintenance item. I don't use the drilled/slotted rotors. |
Hey midnight. I don't know If this would help you but earlier this year I replaced my stock corvette rear calipers with strange dual calipers, 4 pistons each, on each rear wheel. That's a total of 16 pistons in the rear compared to the stock 2. Combined with soft pads this setup could probably hold a freight train at the line. I installed a brake proportioning valve in the rear line to dial in the front rear brake bias.
http://i539.photobucket.com/albums/f...ps08b9094f.jpg |
For reference, I installed the VBP spring in my 89 and it help with nose dive during hard braking situations. Good luck with your application.
I noticed a little difference on the track. I actually liked it. Then my m/c went out and I haven't taken the time to put the DRM spring into the new m/c. Installation is no fun.
On a street car I'm not sure what good it is. Ok, it's always fun to work on the Corvette. Richard Newton My Facebook Page |
Originally Posted by rfn026
(Post 1585681415)
Originally Posted by 383vett
(Post 1585680993)
Originally Posted by c4cruiser
(Post 1585680479)
It may be the current pads on your car that are not doing the job you expect. Another thing may be weak flex hoses on the front.
How's the booster? Vettes seem to be famous for eating them I went through 3 in 5 years on my 90 & yes I had the replacements wrapped in insulation.
Easy check: Park on an incline, engine off let it sit for 5 minutes. Without starting the engine or stepping on the brake put the car in neutral. When it starts rolling apply the brakes. If you have to jam the pedal hard to stop the car the booster is not holding vacuum, its dying. |
The booster is new too but I also have my doubts about it. I put a vacuum canister on to see if low vacuum, (cam) was a problem, it has a gauge on it and I notice the vacuum drops to zero within a short time after shutting the engine off. Also when I put this booster on I had to extend the rod a lot, the pedal was real low with the new booster. The old booster had failed internally. I seriously hope I don't have to do that job again.
(Post 1585685368)
The install is no fun like everyone else has mentioned. I dont track my car very often but I did notice a difference before and after the spring...I'd say for a street car you could skip it.
disclaimer: Mine is a 93, not sure how the 85's may be different. |
Our Bias spring should not affect front line pressure (front brakes)
Randy |
It looks like my "new" booster is defective. I started the car & let it build vacuum on the gauge on the canister. I then clamped the line to the booster so the vacuum would stay in the booster. I then shut the car off and watched the gauge, after several minutes it had only dropped a very slight amount. I then unclamped the line to the booster and the gauge dropped to zero immediately. Naturally, it has been too long now to go back on the seller of the booster but that does not bother me as much as having to do the miserable damn job again. I have a steel booster coming.
(Post 1585689882)
(Post 1585689882)
Edit - I think I understand now - with equal vacuum in the canister and the booster, the guage will only drop if the booster leaked while the hose was clamped. Duh. I am interested in this thread because it seems to take too much pedal pressure on my car as well. I have swapped the booster and m/c, but they were not new, supposed to be "known good units". |
