Originally Posted by RPOZ51
(Post 1585606670)
Looks like it's gonna blow.
:thumbs: |
High center of gravity. High weight. Heat soak monster - are they going to use liquid:air intercooler? Why not just go with turbos? Too easy?
Originally Posted by DDSLT5
(Post 1585610193)
Originally Posted by DRM87
(Post 1585604344)
I would hope in the spirit of the z06 tradition, we are gonna be looking at 605hp.
However to prevent eclipsing the base model it will probably be in the 550hp range. |
Originally Posted by Chicago1
(Post 1585604814)
Keeks said 660 when he posted those pics a year ago,,,,
Originally Posted by CPhelps
(Post 1585606982)
Bigg Gunz was a proven troll and nothing he said about GenV that wasn't already known turned out to be true. I wouldn't put much stock in what he says unless it's already a conclusion you would draw.
That said it seems like they would have to pretty severely sabatoge the LT4 to get fewer than 600 hp. I don't know about you but I like that family right there. Lol |
I know it seems less likely now, but I really hope that is a teaser of the ZR1 engine and the Z06 remains NA.
If the Z06 comes in heavier than the Base C7 that is really going to be a disappointment to many including me. |
Originally Posted by Hirohawa
(Post 1585610963)
Originally Posted by keagan
(Post 1585610362)
Well like everyone except those in the know, we ourselves don't knw if any of it was true but it does hold credence if u believe there will be a ZR1 this generation. Baby LT1(Stingray), upset little sister (Z06), big brother (ZR1).
I don't know about you but I like that family right there. Lol I'm not disagreeing with the engine setup possibilities you mention, just pointing out that anything Bigg Gunz said is not credible. |
(Post 1585610963)
Why not just consider that there may not be a ZR1? Is it really that hard to swallow?
Originally Posted by CWW17
(Post 1585610311)
He simply did not say this. Stop spreading this rumor.
(Post 1585611387)
I'll be disappointed as well but if they are going w/ an S/C/intercooler setup I don't see how they will offset that extra weight without going cost prohibitively exotic. Maybe if they do a Z/28 style track stipper model...
i still cant believe its not gonna be turbos
Originally Posted by disc0monkey
(Post 1585612278)
In the meantime, the top mounted centri S/C is one of the wildest OEM FI solutions I've seen in awhile. That is too cool. Should make power out to redline just like everyone likes. The car is gonna be a monster. :yesnod: |
(Post 1585611374)
We know a lot of what he said was not true. The claims he made about the "un-crackable" ECU using encryption methods was totally false. We know the "self tuning" was totally false. Nothing he predicted that wasn't already common knowledge or a pretty obvious conclusion based on what we knew already came to be true.
"Little Sister", could that be the rumored lower cost C7 with the 5.3 that was rumored for awhile?
http://wot.motortrend.com/not-a-stin...ks-333741.html http://www.corvetteblogger.com/2013/...e-c7-corvette/ |
:cool:
they won't put out a Z06 that will surpass the '13 ZR1's 638hp.. that would totally screw the guys that just put out 120k for the fastest last year. my guess is 605hp like DRM87 said, to keep the 405 - 505 - 605 tradition. :D
Originally Posted by bptuner
(Post 1585608434)
good luck to the gear heads that love wrenching to get more power like myself. bolt ons and fuel is all your gonna be able to do but I am curious to know how much boost it will push stock and what its capable of
1st off there is the possibility of different or better blade design. 2nd if this does end up having an electric motor, that will REALLY open up some options. 3rd....if they can put one big one in the middle, why can someone put 2 smaller ones there? Rarely does a new innovation start with it's own end. |
