1961 Dual-Point Distributor Lubrication
1 Attachment(s)
What is the best specific lubrication procedure for the internals of this distributor (a 270 HP 2x4)?
I believe the only lubrication required is on the cam.
There is usually a felt wick to which a drop or 2 of oil is all that is required. |
1 Attachment(s)
The external oil tube on stock distributors provides 'internal' lubrication and requires a few drops of motor oil every 5,000 miles according to the ST-12.
I like!
A little dieelectric grease from the electronic supply store (non conductive) I also have some in my plug boots!!!!!! Or the Volkswagen guys with selling a little OO9 mechanical advance distributor sell a little grease packet for that purpose. I got rid of things that ride on lobes, except for the cam!!!!! Thus I have magnetic pickups on my stuff!!!!!! I haven't had to grease that up anymore!
Yes I know what you are talking about!!!!!!!!!! Hope that helps!!!!!!! |
1 Attachment(s)
The oiler tube with the GITS cap in Frankie's photo in post #3 lubricates the upper mainshaft bushing - there's a tubular wick extending from the bottom of that tube that puts oil on the bushing. Lubrication of the points is a drop or two of distributor cam grease when you change the points or set the dwell. :thumbs:
John Z, you are truly awesome, except when
Originally Posted by JohnZ
(Post 1585308720)
