WTS: 89-91 Set of front and rear FX3 Shocks
WTS two front and two rear 89-91 FX3 working shocks. Two (revised ad) of the shock covers is dented (not the shock itself). One shock cover is slightly dented the other one is probably unusable. You can use one from your old set. Gears on all for shocks are good also, with no broken teeth. You can use these shocks as swing set while you send your originals out to be rebuilt.
Two front and two rear for $120.00. PM for shipping. PM for alternative to Bilstein rebuild service. |
3 Attachment(s)
Pictures. Front shocks on the right side of photo. You can see the dented covers and where it rubbed off paint. Underlying shock looks good.
ttt
ttt
