C7 Jack Pucks In Stock On Sale! Leave-In Style, Easy Install
As many of you know, you risk damaging your Corvette when you or a shop tries to lift it without have proper jack pads in place. Why take the risk of getting your prized possesion back with damaged rockers? Our new, lightweight ABS plastic Jack Pucks will save you the aggrevation and you'll know they are always there. Take it to the dealer, a performance shop or the tire shop without worries. You'll always have these pucks ready to protect, invisible to everyone! Sold as a set of 4, we have these marked down to: $49.99 A SET! Click here to order: http://www.corvettemods.com/Corvette...R-_p_9265.html http://imagizer.imageshack.us/v2/640...9/85641208.jpghttp://imagizer.imageshack.us/v2/640.../dsc09969a.jpg |
Originally Posted by corvettemods1
(Post 1585286341)
:thumbs:
Rich |
How do you remove the pucks once there are installed if they need to be removed?? I know a dumb question but someone had to ask it.
THANKS!! |
Originally Posted by MThomas
(Post 1585417576)
THANKS!! |
Aren't these made by or the same as BMW pucks?
Originally Posted by Ammo
(Post 1585424196)
Will the ones I have on my C6 fit on the C7? They look the same in your picture and I think I bought them from you a few years ago.
I have a set on my C7.
Great peace of mind. |
I would rather not leave them on and only put on if I need them, are the easy to get off if not needed and put back on when needed?
Why take them off? Extra weight or what. You can't see them unless you are on the floor and they look like the car came from BG with them. :thumbs:
Originally Posted by Gr8ful
(Post 1585492165)
http://i67.photobucket.com/albums/h3...EA37F8187F.jpg |
I will definitely buy a set when my car arrives, somewhere along the way the front fender of my C5 got cracked, I'm not letting that happen again.
(Post 1585492165)
There is a good chance I may choose to leave them on but I would like to have the option to take the on and off repeatedly with wearing out the clips. There is a good chance I may never need to used them. I had a few leased cars that I turned in without ever changing the tires or fixing a flat but I did get a flat on my Volt when it was 20 months old (probably the first flat in 10 or 15 years maybe longer) |
What is the diameter of the pucks? Also, how do these compare to the aluminum pucks you also sell? Which are better?
Originally Posted by Buzzardz_vette
(Post 1585632927)
About 3.5" roughly. These are leave in, the aluminum are for usage at the time of need then removed. |
(Post 1585633292)
(Post 1585633383)
I thought the manual says the puck can't be larger than 2.5".
(Post 1585633564)
Went and measured one, The contact portion is 2.25"
I have a set on my C7 and they fit fine.......
Originally Posted by rpoz06
(Post 1585634300)
