Originally Posted by race105
(Post 1585228674)
Hello all. I would like to introduce myself to the forum. My name is Jordan out of northern NJ and recently purchased 06 Z06 w 30k miles. Needless to say after a couple thousand miles I had a major engine failure and I need to pull the motor. (hole in oil pan) I have a 2 post lift and I am going to pull the motor myself. Does anyone have a tutorial on how to pull the drivetrain from this car or is my best bet to purchase a service manual?? Thanks in advance guys. I have an extensive mechanical background and all the proper tools at my disposal I just want to be prepped going in and learn some tricks of the trade before I tackle the job.
Any pics? Thanks |
2 Attachment(s)
Hello all update on progress.. Pulled drive train tore heads off quickly Both front cylinders grenaded both front cylinder exhaust valves were gone.. Destroyed block, pan, heads etc. I haven't had a chance to pull the timing cover to see if that had any role in this mess I will get to that today hopefully.. Needless to say a long block is in my future...
1 Attachment(s)
This is one of the better pictures intake full of metal
Wow .. that really sucks.
Originally Posted by DaOtherOne
(Post 1585246205)
What a bad break. Best of luck getting back on the road. |
That is how the last one looked. We replaced the inake,cooler etc due to too much shrapnel.
I'm going to be going w a TSP 441 long block w 285 cc heads w titanium valves, forged internals, callies comp star H beam rods, high flow oil pump.. That should do the trick.. If it blows apart then I will contemplate suicide...
On a more positive note now i can make one of those really cool engine block coffee tables with the left over scrap metal lol
(Post 1585247426)
mistype... titanium intake stainless exhaust
"the fix" is, don t buy a LS7, and sell the one you have !
Originally Posted by walleyejack
(Post 1585247929)
Can't that block be resleeved? Steve Demirjin at R.E.D. could tell you.
Then just buy some ported LS7 heads off of here and put it back together http://forums.corvetteforum.com/c6-p...ls7-heads.html |
There is a giant hole in the side of the block or I would have considered it. At this point I feel the only way to really be sure this thing will be perfect is to replace everything and start fresh. Does anyone have any info or insight on how to flush the dry sump system so I can be sure all of the metal has completely been removed?
Originally Posted by gnx7
(Post 1585248478)
horrific damage :ack:
OP, G-L with your new build. |
Sorry to hear about your loss OP and best of luck getting back on the road with a new and improved engine. These LS7 engines certainly seem to be failing at an alarming pace. :(
