Cranes Corvette has the correct generator for $309. I just need to know if I need to replace my existing pulley. Please see photos. Thanks
Originally Posted by 6vette1
(Post 1585211037)
Rich |
Those are the dimensions of my pulley and fan
2 Attachment(s)
I have a 1961 2x4 with generator #1102041. Is this right? The amp gauge pegs out high when rpms go up. What should I look for to solve this.
That generator pictured does have the right end cap and not the passenger car version...good for you.
Big Alvie - you may have a voltage regulator that has gone bad....measure across your battery terminals with the engine at about 2000-2500 RPM...if the voltage is much over 14.2V you need to jump on the issue quickly or wiring/component damage will result. The '61 Passenger Car Manual has more extensive tests to isolate the exact problem. |
