CF Diffuser recommendation
Any recommendations for a CF diffuser? Looking for something that has quality build, appearance, fitment, and is easy to install.
Ideally the OEM Reverse lights would bolt right in, but open to other options as well. I have seen options from American Hydrocarbon and C7 Carbon. Not a fan of the reverse light setup on the APR. |
I've got an APR setup. It's a functional diffuser. I have a backup cam installed and can see fine at night with the APR setup. Even with no backup lights in the dark, the backup cam allows me to see behind the car.
Originally Posted by rhathawy
(Post 1585008410)
Still looking for feedback. Thanks.
1 Attachment(s)
I have the APR Diffuser it has the LED reverse lights that are mounted of each of of the license plate, you will have to look to see them on the ledge above the plate and they are bright. The quality of the APR is really good and perfect fitment. I have one of the other brands you mentioned on another Vette and it is very poor fitment and the mounts for the reverse lights is horrible. Hope this has helped some.
Derwin |
I have the APR too and the quality and fitment is perfect
Breathless Performance has the nicest (to me) diffuser by far, but requires the additional purchase of custom exhaust. That being said, it still looks bad-ass and is at the top of my wishlist.
I have a CF rear diffuser from American Hydrocarbon. The fit was pretty good and finish was very good. There was a small gap on the top of one of the back up lights but it isn't noticeable unless you get down really low to look for it.
http://i987.photobucket.com/albums/a...ps717191b4.jpg http://i987.photobucket.com/albums/a...psbbc4ada6.jpg http://i987.photobucket.com/albums/a...psee9d1afa.jpg http://i987.photobucket.com/albums/a.../1015-0216.jpg http://i987.photobucket.com/albums/a.../1014-0216.jpg http://i987.photobucket.com/albums/a.../1013-0216.jpg http://i987.photobucket.com/albums/a.../1012-0216.jpg |
Originally Posted by Yellow C-6
(Post 1585029724)
Derwin
Originally Posted by mcandrew67
(Post 1585030107)
Originally Posted by WICKEDFRC
(Post 1585030124)
Originally Posted by ncvette_1FUNRIDE
(Post 1585030241)
I have a CF rear diffuser from RPI. The fit pretty good and finish was very good. The was a small gap on the top of one of the back up lights but it isn't noticeable unless you get down really low to look for it.
Originally Posted by Jawnathin
(Post 1585062072)
Thanks. Did not know RPI made one. I couldn't find it on their site. Can you share a link? http://www.rpidesigns.com/shop/item.aspx?itemid=987 |
Another vote for APR. Quality is top notch and fit is perfect. IMO it looks a lot better without the stock reverse lights. The LED lights are a lot brighter than you think. You couldn't miss them from behind the car. The APR diffuser isn't just for looks, it's a truly functional diffuser if that's what you're looking for. Mine's been on for a couple of years, including some high speed (160+ mph) road racing and it still looks brand new.
(Post 1585062087)
After more searching (Diffuser didn't pull it up) I found this. Is this what you bought? Is it a replacement or just a cover? The description seems to indicate that it is just a cover that you lay on top of the existing one.
http://www.rpidesigns.com/shop/item.aspx?itemid=987 I got the FULL Carbon Fiber rear diffuser from American Hydrocarbon when it was on sale. :thumbs: http://forums.corvetteforum.com/c6-c...-diffuser.html NOTE: I will mention that American Hydrocarbon had a batch of these that went out before mine, that had fitment problems. I waited until they fixed the problems before I ordered mine. |
(Post 1585064523)
My fault! :hide: I got confused about where I got my Carbon Fiber side skirts and front splitter with where I got the rear diffuser.
I got the FULL Carbon Fiber rear diffuser from American Hydrocarbon when it was on sale. :thumbs: http://forums.corvetteforum.com/c6-c...-diffuser.html NOTE: I will mention that American Hydrocarbon had a batch of these that went out before mine, that had fitment problems. I waited until they fixed the problems before I ordered mine. https://lh4.googleusercontent.com/-k...0/100_3069.JPG https://lh3.googleusercontent.com/-1...0/Exhaust2.JPG |
Originally Posted by Steve_R
(Post 1585062172)
(Post 1585064523)
Originally Posted by Racer
(Post 1585065200)
My wife has a West Coast Corvette stick on and I have the American Hydrocarbon replacement one. As mentioned, it is stock shape but with a nice c/f finish. The only real problem with my wifes is how they cut out around the reverse lights.
Anything out there actually functional or just cosmetic? Most of these look to be cosmetic factory replacements.
Supervettes is perfect and while yur at it get some quarters too...
led reverse lights look great at the front of the tunnel |
Originally Posted by Drewstein
(Post 1585071631)
(Post 1585070931)
Thanks. Not so concerned with the brightness actually, just don't like how the reverse lights look. Appreciate knowing the APR is a quality piece though and I'm still keeping that in mind.
Okay, thanks for the clarity. Sounds like they should have hammered all of that out by now. I think American Hydrocarbon might be the ticket for me. Thanks, which one do you like more? I assume the top is your wife's and the bottom is yours? |
(Post 1585075385)
Functional?? If it is a direct replacement then it is functional.
Thanks, gonna take a good look at the American Hydrocarbon one.
Just not a fan of the APR's reverse light setup. |
