76 Front Fenders alignment
I had body mounts replaced and noticed there is a gap on the upper portion of doors and left fender is only inch or so above tire. Can someone provide instructions how to adjust the fenders?
The center I took the car to said that is the way the car was, but I know it wasn't. so basically I'm on my own to fix. |
Originally Posted by rgpta
(Post 1584923855)
The center I took the car to said that is the way the car was, but I know it wasn't. so basically I'm on my own to fix. DUB |
(Post 1584923855)
The center I took the car to said that is the way the car was, but I know it wasn't. so basically I'm on my own to fix. An inch of free space between the tire and the fender is small. The bodymounts need to be shimmed from the frame according to the original factory shim stack. So check that first. If that's ok, then look at the connection of the radiator support to the front frame. |
Pictures
2 Attachment(s)
Here is what it looks like
