Rocks in between rocker panel
Hello all! I know of the common problem with rocks in between the body panels just below the rear break duct. I know how to do the fix on the regular z06. How do you get the rocks out on a car with the side skirts. The appears to be one bolt but then the rest seem to have a proprietary head/rivot. Any thoughts? Thanks!
Are you talking about rocks between the carbon fiber skirts and the body? There is a foam strip between the body and the skirts that is supposed to minimize this. If you need to remove the carbon fiber skirt you will have to drill out the rivets. There are also a few screws. The rivets are ordinary break stem rivets. The dealer should be able to get them. They come in the kit with the rocker for the dealer to install. Bowling Green never installed the rocker skirts. They put them inside the car for delivery and the dealers drilled the rivet holes.
Originally Posted by radchad3
(Post 1584872945)
