Thanks!
Wow - great stuff.
I saw somehwere that the rear 12v plug is where the CTEK battery tender gets plugged in. Very well thought out interior. |
Thanks.... what is the "Off" switch next to hatch open switch?
Originally Posted by THECORVETTEMANN
(Post 1584833269)
Wow - great stuff.
page 2-18 in the owners manual......
Originally Posted by H101
(Post 1584833282)
"Intrusion and Inclination Sensors Disable Switch: It is recommended that the intrusion and inclination sensors be deactivated if pets are left in the vehicle or the vehicle is being transported. With the vehicle turned off, press d on the right side of the hatch release button. The indicator light will come on momentarily, indicating that these sensors have been disabled for the next alarm system arming cycle." |
(Post 1584833282)
S. |
(Post 1584833282)
Is this a 2 or 3LT?
Thanks! There are really nice high quality photos! :thumbs:
Is that an LED light in the compartment behind the screen? |
Originally Posted by aerocombatpilot
(Post 1584833630)
Is this a 2 or 3LT?
Originally Posted by RickDI
(Post 1584833644)
Originally Posted by talon90
(Post 1584833369)
The uplevel (2LT/3LT) security system has a motion sensing feature for "Intrusion Detection". That turns off the sensor - for example, if you leave a pet in the vehicle, you don't want it setting off the alarm if fido moves...LOL.
Can you please give us a little more detail on the Intrusion Detection option that comes with the 2LT/3LT? Thanks in advance. B. |
The big question is - do the airbag warning stickers come off easily? :D
Thanks, Brian |
Does the 1LT have the same closed loop carpeting? It looks excellent in the photos. Thanks.
Originally Posted by BPhillyc7
(Post 1584833726)
Hi Paul. Great detailed photos. Thank you for posting!
Originally Posted by brian98vette
(Post 1584833763)
Thanks, Brian |
Originally Posted by rcallen484
(Post 1584833777)
(Post 1584833269)
Wow - great stuff.
(Post 1584833349)
That is correct. It is for the tender.
Originally Posted by Gearhead Jim
(Post 1584833851)
The photos make me think you must leave the trunk open, or run the wire out through one of the doors/windows, when using the battery maintainer. Is that correct?
If you have enough cord, you could leave the window cracked open and run it out through the front. |
