Thoughts on removing the rubber/plastic lip under nose?
My new driveway has a bump that will not clear the 2.5in clearance of the 3 piece front plastic lip guard. There is a 6-10 inch 45 degree incline and then flat driveway.
I can hear it scraping the lip and distorting it to the point it seperates from the plastic button holding it to other pieces. I have tried coming in at all angles. What are my options? -Remove entire plastic lip guard -Back in? -do they make a higher lip guard? Is it a DIY pop off or does dealer have to do it. Thanks |
You can take it off in about 3 minutes. Its not hard at all.
Mine hits too and it sounds just like what yours is doing. I wouldnt take it off but I am debating on "trimming" it up slightly to see how it does. Be simple to take it off, mark it, cut it, and then smooth the cut surface so its not sharp. |
Pretty easy to remove. I have replaced mine after it was destroyed be a road gator.
Mine scrapes also....has also come loose from the plastic pins holding the 3 parts together. I just live with it.:D Could replace it again, but it would end up the same so why spend the money. No one can see it anyway. |
I have the same problem. It is a bolt on piece, and easily removed. I don't think it really has any value other than appearance. I would like to put a "splitter" on mine, but that would scrape just as badly....:ack:
Originally Posted by carpe dm
(Post 1584726446)
I trimmed about an inch off mine as I also have an inclined driveway.
I still have to come in at an angle, but it doesn't scrape anymore. :cheers: |
Originally Posted by wayback
(Post 1584726461)
It is for high speed runs....keeps the front from lifting. :cheers: I believe it is there to help direct air up into the radiator, and is needed for cooling. If it scrapes all the time, I guess you could shave maybe in inch off it so it would not set so low. Removing it is a bad idea. |
Mine scrapes for the last several years, haven't seen any damage that I feel I need to remove it.
(Post 1584726461)
It is for high speed runs....keeps the front from lifting.:cheers:
Mine also scrapes. So does my splitter. I went to Home Depot and bought 20"x20" rubber patio blocks. About 6 bucks apiece.
I back down until I hear it scrape. Pull forward and put the blocks behind the front wheels to build it up. I then back out slowly. I only do this because of the splitter scraping not the air dam. If it were just the air dam I could live with it. |
Originally Posted by SilverScorp
(Post 1584726818)
I dont think so. I thought it directed air up across the radiator to help keep it cool.
It has nothing to do with downforce. It is important for cooling. Do not remove it. It's a wear item. It scrapes. It's cheap and easy to replace if it needs it. Removing or trimming it is a bad idea. Given all of that I don't understand the obsession some have with it rubbing and the lengths people will go to to stop it from rubbing. It doesn't hurt anything then it rubs.
i got into a huge discussion over those 3 rubber pieces about a month ago. some claim that they create lift a speed, i don't believe it since they don't on my coupe (i took them off & tried it) they are there to direct air into the radiator.
you can trim them if you want or just SLOWLY BACK into your driveway. they are rubber and will fold and yes RUB will will not get damaged. on wide body cars the lower air dam does get damaged especially the CF piece & that is expenssive. some have used planks of wood as a ramp if the transition is too great. |
remove to 2 sides and leave the middle section
Originally Posted by Steve_R
(Post 1584726885)
Originally Posted by TLS_Addict
(Post 1584726913)
It draws attention.
Mine's been rubbing for over eight years (twice a day). It's made to rub. If it ever gets to the point of looking bad I'll replace it. :toetap:
Originally Posted by speedraider
(Post 1584726909)
If you dont want to remove, try googling ramp systems and you may find something that works and does not look hideous. My $1.02 (inflation adjusted)
Took mine off, been over two years now and my car is fine. Couldn't stand the scraping. Sometime embarrassing just like the brake squeal.
