2000 Vette convertable has intermittent won't start problem
CALL ME FRUSTRATED:
SOME TIME BACK I WAS ON THE FORUM AND LISTED A NOTE THAT MY 2000 CORVETTE WOULDN'T START "EVERY ONCE IN AWHILE". AND YES THE LIGHTS COME ON WHEN YOU TURN ON THE KEY AND THEY DIM WHEN YOU TRY AND START THE CAR. HERE IS WHAT IT ACTS LIKE: "SIMPLY A LOOSE GROUND" NOT CHECKED ALL CONNECTIONS ON THE BCM, BATTERY, ETC. ANY HELP > HERE ARE THE CODES AS SEEN: >PCM 1 CODE > P1631H >AO-LDCM CODE> B2262H "unable to clear it" > B2264H "unable to clear it" IF THERE IS ANYONE THAT COULD HELP ME>PLEASE CHIME IN. >THANKS |
Suggest you read the Bill Curlee threads on the ignition switch
If you are comfortable with a voltmeter then do all of the suggested diagnostics. Your problem may be caused by something else. I went through an intermittent start problem last year and I tried to give feedback to all who helped me. My problems were caused by bad contacts in the switch. Do some searches and some reading, there are lots of good threads on this forum. |
Originally Posted by c51stvette
(Post 1584596093)
If you are comfortable with a voltmeter then do all of the suggested diagnostics. Your problem may be caused by something else. I went through an intermittent start problem last year and I tried to give feedback to all who helped me. My problems were caused by bad contacts in the switch. Do some searches and some reading, there are lots of good threads on this forum. ok THANKS |
Originally Posted by patrickdelahoussaye
(Post 1584595601)
Starter was replaced.
