Pfadt Headers/HP Tuners/Innovate A/F/Custom Tune
We have put a package together that contains everything you need to add a minimum of 50RWHP to your C6/C6GS/ZO6 SAFELY Package Includes: (1) Set Pfadt 05-13 Corvette C6/C6GS Complete Header, X-Pipe, Gasket, O2 Sensor Extender Package with Cats (1) HP Tuners VCM Suite (1) Innovate Wide Band A/F Gauge complete Kit (1) Custom Dyno Tune This package conservatively makes 50RWHP. The tune was developed on a dyno and dyno tested and installed on many C6 C6GS cars. Comes with the Innovate Wide Band and Gauge that fits in the existing bung on the Pfadt Headers. Monitor your Air Fuel Ratio's continuously. The VCM Editor also allows modification of the saved binary image. The VCM Editor allows all parameters such as Spark, Fuel, RPM Limits, FAN Temps, Transmission Shift points and pressures, Speedometer settings and many, many more. The editor provides an easy to use graphical interface and many powerful table manipulation capabilities such as copying, scaling and shifting to name a few. Custom tune has everything already calibrated, fuel, spark, proper A/F Ratios, Header calibration. Its easy as 1,2,3 Install your headers and wide band, Install the HP Tuners Software on your laptop, connect your laptop to your vehicle and flash the VCM/PCM with the custom tune we provided. Start your vehicle and ENJOY YOUR POWER PFADT HEADERS INNOVATE A/F SENSOR & GAUGE HP TUNERS VCM SUITE CUSTOM TUNE $2785.99 delivered lower US We have a number of HP Tuner Interfaces if you don't plan to do any further tuning to your car. You can purchase this package upload your tune RETURN THE INTERFACE BACK TO US UNDAMAGED & WE WILL REFUND YOU $375.00 (must return interface within 10 days) Now You get Pfadt Headers Innovate Wide Band Custom Tune (Custom tune has everything already calibrated, fuel, spark, proper A/F Ratios, Header calibration, CAI) Additional custom tuning is extra Return Freight Paid on Tuner Interface $2398.95 |
We have put a package together that contains everything you need to add a minimum of 50RWHP to your C6/C6GS/ZO6 SAFELY Package Includes: (1) Set Pfadt 05-13 Corvette C6/C6GS Complete Header, X-Pipe, Gasket, O2 Sensor Extender Package with Cats (1) HP Tuners VCM Suite (1) Innovate Wide Band A/F Gauge complete Kit (1) Custom Dyno Tune This package conservatively makes 50RWHP. The tune was developed on a dyno and dyno tested and installed on many C6 C6GS cars. Comes with the Innovate Wide Band and Gauge that fits in the existing bung on the Pfadt Headers. Monitor your Air Fuel Ratio's continuously. The VCM Editor also allows modification of the saved binary image. The VCM Editor allows all parameters such as Spark, Fuel, RPM Limits, FAN Temps, Transmission Shift points and pressures, Speedometer settings and many, many more. The editor provides an easy to use graphical interface and many powerful table manipulation capabilities such as copying, scaling and shifting to name a few. Custom tune has everything already calibrated, fuel, spark, proper A/F Ratios, Header calibration. Its easy as 1,2,3 Install your headers and wide band, Install the HP Tuners Software on your laptop, connect your laptop to your vehicle and flash the VCM/PCM with the custom tune we provided. Start your vehicle and ENJOY YOUR POWER PFADT HEADERS INNOVATE A/F SENSOR & GAUGE HP TUNERS VCM SUITE CUSTOM TUNE $2785.99 delivered lower US |
We have put a package together that contains everything you need to add a minimum of 50RWHP to your C6/C6GS/ZO6 SAFELY Package Includes: (1) Set Pfadt 05-13 Corvette C6/C6GS Complete Header, X-Pipe, Gasket, O2 Sensor Extender Package with Cats (1) HP Tuners VCM Suite (1) Innovate Wide Band A/F Gauge complete Kit (1) Custom Dyno Tune This package conservatively makes 50RWHP. The tune was developed on a dyno and dyno tested and installed on many C6 C6GS cars. Comes with the Innovate Wide Band and Gauge that fits in the existing bung on the Pfadt Headers. Monitor your Air Fuel Ratio's continuously. The VCM Editor also allows modification of the saved binary image. The VCM Editor allows all parameters such as Spark, Fuel, RPM Limits, FAN Temps, Transmission Shift points and pressures, Speedometer settings and many, many more. The editor provides an easy to use graphical interface and many powerful table manipulation capabilities such as copying, scaling and shifting to name a few. Custom tune has everything already calibrated, fuel, spark, proper A/F Ratios, Header calibration. Its easy as 1,2,3 Install your headers and wide band, Install the HP Tuners Software on your laptop, connect your laptop to your vehicle and flash the VCM/PCM with the custom tune we provided. Start your vehicle and ENJOY YOUR POWER PFADT HEADERS INNOVATE A/F SENSOR & GAUGE HP TUNERS VCM SUITE CUSTOM TUNE http://www.xplosiveperformance.com/0...s-_p_3558.html $2785.99 delivered lower US http://www.xplosiveperformance.com/t...axx=300&maxy=0 http://www.xplosiveperformance.com/t...axx=300&maxy=0 http://www.xplosiveperformance.com/t...axx=300&maxy=0 |
We have put a package together that contains everything you need to add a minimum of 50RWHP to your C6/C6GS/ZO6 SAFELY Package Includes: (1) Set Pfadt 05-13 Corvette C6/C6GS Complete Header, X-Pipe, Gasket, O2 Sensor Extender Package with Cats (1) HP Tuners VCM Suite (1) Innovate Wide Band A/F Gauge complete Kit (1) Custom Dyno Tune This package conservatively makes 50RWHP. The tune was developed on a dyno and dyno tested and installed on many C6 C6GS cars. Comes with the Innovate Wide Band and Gauge that fits in the existing bung on the Pfadt Headers. Monitor your Air Fuel Ratio's continuously. The VCM Editor also allows modification of the saved binary image. The VCM Editor allows all parameters such as Spark, Fuel, RPM Limits, FAN Temps, Transmission Shift points and pressures, Speedometer settings and many, many more. The editor provides an easy to use graphical interface and many powerful table manipulation capabilities such as copying, scaling and shifting to name a few. Custom tune has everything already calibrated, fuel, spark, proper A/F Ratios, Header calibration. Its easy as 1,2,3 Install your headers and wide band, Install the HP Tuners Software on your laptop, connect your laptop to your vehicle and flash the VCM/PCM with the custom tune we provided. Start your vehicle and ENJOY YOUR POWER PFADT HEADERS INNOVATE A/F SENSOR & GAUGE HP TUNERS VCM SUITE CUSTOM TUNE http://www.xplosiveperformance.com/0...s-_p_3558.html $2785.99 delivered lower US We have a number of HP Tuner Interfaces if you don't plan to do any further tuning to your car. You can purchase this package upload your tune RETURN THE INTERFACE BACK TO US UNDAMAGED & WE WILL REFUND YOU $375.00 (must return interface within 10 days) Now You get Pfadt Headers Innovate Wide Band Custom Tune (Custom tune has everything already calibrated, fuel, spark, proper A/F Ratios, Header calibration, CAI) Additional custom tuning is extra Return Freight Paid on Tuner Interface $2398.95 |
Hear the Pfadt Tri-Y's Corsa Extreme Axle Back https://www.facebook.com/photo.php?v...type=2&theater https://www.facebook.com/photo.php?v...type=2&theater |
We have put a package together that contains everything you need to add a minimum of 50RWHP to your C6/C6GS/ZO6 SAFELY Package Includes: (1) Set Pfadt 05-13 Corvette C6/C6GS Complete Header, X-Pipe, Gasket, O2 Sensor Extender Package with Cats (1) HP Tuners VCM Suite (1) Innovate Wide Band A/F Gauge complete Kit (1) Custom Dyno Tune This package conservatively makes 50RWHP. The tune was developed on a dyno and dyno tested and installed on many C6 C6GS cars. Comes with the Innovate Wide Band and Gauge that fits in the existing bung on the Pfadt Headers. Monitor your Air Fuel Ratio's continuously. The VCM Editor also allows modification of the saved binary image. The VCM Editor allows all parameters such as Spark, Fuel, RPM Limits, FAN Temps, Transmission Shift points and pressures, Speedometer settings and many, many more. The editor provides an easy to use graphical interface and many powerful table manipulation capabilities such as copying, scaling and shifting to name a few. Custom tune has everything already calibrated, fuel, spark, proper A/F Ratios, Header calibration. Its easy as 1,2,3 Install your headers and wide band, Install the HP Tuners Software on your laptop, connect your laptop to your vehicle and flash the VCM/PCM with the custom tune we provided. Start your vehicle and ENJOY YOUR POWER PFADT HEADERS INNOVATE A/F SENSOR & GAUGE HP TUNERS VCM SUITE CUSTOM TUNE http://www.xplosiveperformance.com/0...s-_p_3558.html $2785.99 delivered lower US We have a number of HP Tuner Interfaces if you don't plan to do any further tuning to your car. You can purchase this package upload your tune RETURN THE INTERFACE BACK TO US UNDAMAGED & WE WILL REFUND YOU $375.00 (must return interface within 10 days) Now You get Pfadt Headers Innovate Wide Band Custom Tune (Custom tune has everything already calibrated, fuel, spark, proper A/F Ratios, Header calibration, CAI) Additional custom tuning is extra Return Freight Paid on Tuner Interface $2398.95 http://www.xplosiveperformance.com/t...axx=300&maxy=0 |
