Now that we know the weight of the Z51...
The Motor Trend article pegged the 3LT Z51 at I believe 3,444 lbs? (Might be a few lbs off I can't recall exactly now). Sounds like its about 150 lbs more than a non-Z51 1LT. Will the difference in gearing and slightly better tires still make the Z51 faster in a straight line than the non-Z51 despite the 150 lb difference? That's comparable to having an extra passenger in the car at all times.
I'm happy with the Z51's acceleration, what I'd like to know is how will the non-Z51 compare? I'm guessing it'll be hard to find road tests for the non-Z51. Consider 0-60, 1/4 mile, and 30-100 mph rolling acceleration. |
3,444 lbs!?! That must be a mistake - cause if not then this car is an oinker.
I'm curious if they will try to put a positive spin/marketing BS on how this is actually good. |
Originally Posted by Achmed
(Post 1584485878)
Originally Posted by Hirohawa
(Post 1584485927)
I'm curious if they will try to put a positive spin/marketing BS on how this is actually good. S. |
My suggestion: Don't eat at Ihop before going for a ride.
You'll add too much weight to the car. :) |
(Post 1584485878)
I'm happy with the Z51's acceleration, what I'd like to know is how will the non-Z51 compare? I'm guessing it'll be hard to find road tests for the non-Z51. Consider 0-60, 1/4 mile, and 30-100 mph rolling acceleration. MT did comment that the C7 was 69 lbs heavier than the last GS they tested. The last GS they tested was against a 991 911 and they listed it at 3375. GM lists the weight of a '13 GS as 3311. So figure the Z51 is ~82 lbs heavier than a non-Z51 car. That's some really fuzzy math, lol. So a ~.2/2mph advantage based on weight offset by a slight gearing advantage and a wash in tires (slightly wider vs. higher aspect ratio). IMO, a base, lightly optioned non-Z51 car will be quicker. S. |
Originally Posted by Snorman
(Post 1584486095)
Without any details relative to a base car (from MT), IMO it is hard to compare.
MT did comment that the C7 was 69 lbs heavier than the last GS they tested. The last GS they tested was against a 991 911 and they listed it at 3375. GM lists the weight of a '13 GS as 3311. So figure the Z51 is ~82 lbs heavier than a non-Z51 car. That's some really fuzzy math, lol. So a ~.2/2mph advantage based on weight offset by a slight gearing advantage and a wash in tires (slightly wider vs. higher aspect ratio). IMO, a base, lightly optioned non-Z51 car will be quicker. S. So it's possible that someone could have a C7 Z51 auto 2LT or 3LT weighing in at around 3,500 lbs (using the MT article weight for the 7 spd car as a base). This car would be 250lbs more than a 1LT C6 LS3 "narrow body". That would be one interesting race, straight line at least. |
Originally Posted by Goaty
(Post 1584486359)
Does the weight of the car vary by option package? Meaning that a 3LT Z51 would be heavier then a 1LT Z51? For example on the C6 they list the coupe at 3225 lbs, I assume this is for the lightest configuration, 1LT 6 speed, it couldn't possibly be the same for a 4LT Auto.
So it's possible that someone could have a C7 Z51 auto 2LT or 3LT weighing in at around 3,500 lbs (using the MT article weight for the 7 spd car as a base). This car would be 250lbs more than a 1LT C6 LS3 "narrow body". That would be one interesting race, straight line at least. The higher optioned cars have to weigh a bit more with HUD, heated/vented seats, upgraded audio, etc.. I too am curious how much more. S. |
Best solution wait for the C8.
Originally Posted by Jp23rockstar
(Post 1584486461)
69 pounds more than the last Grand Sport tested by Motor Trend
Originally Posted by sam90lx
(Post 1584486615)
At the rate things are going it may weigh 4000 lbs.
anyone know the gears in both z51 and non? meaning first gear goes to what in the z51 stick car?
Well I needed to diet anyway. Replace the battery with a Lipo type $$$ could help too.
LOL. |
The magazine weights are totally inconsistent and have nothing to do with Mfr curb weight. And there is no way the Z51 package adds 150lb over a base car. Maybe 50. I believe the curb weight on the base car is 3,298, so I'd guess the mfr curb weight for the Z51 will come in at 3,350 or thereabouts - pretty much same as the GS. In any case, I'm sure GM will be publishing the official number very soon.
Originally Posted by TTRotary
(Post 1584486900)
MFG's give a single number for all cars no matter the options and aren't very forthcoming regarding fluid fill. I'd take a magazine weight any day over the MFG estimate. Given that some magazines have weighed well equipped C6's ranging from 3310 (Z06) to 3440 (GS Vert), I don't see a huge issue with the weight, although I definitely would have liked to see it closer to 3300: http://www.roadandtrack.com/cm/roada...51ba6b2de4.pdf My impression from the article is the 3444 is the Z51 with 3LT, which probably adds some weight due to the extra leather and suede packages. Possibly a 1LT with Z51 would be less, and the base would be less still. -T |
(Post 1584485967)
Your backhanded swipes at the C7 are getting as dated as your C6's interior was in 2009.
S. |
Notable quote in the MT article from Juechter: "It would be easy to make the car light if we weren't worried about fuel consumption."
So the hope is that when they make a performance model they will leave off the 4 cyl. mode. Not only would the engine be lighter, but they could get rid of the steel torque tube (18 lbs saving by itself) and the extra exhaust valves. Give Chevy props though, the article mentioned that because the car does not default into 4 cyl mode (like Porsche) they could not take full credit for the MPG in that mode (rated it at 29 instead of 30 mpg highway). I for one am glad I don't have to turn the thing off everytime, I can leave it in the mode I want. It also mentioned the 4cyl. mode is only active in the ECO mode on the 7 spd, but will be used in the first three modes for the automatic version. |
(Post 1584486774)
The weight target should of been the 911 which comes in at 3245lbs. I can only imagine the Z06 version coming in at 100lbs more than the current Z06.
What was the name of that pig on Green Acres? The C7 Z51 can be affectionately known as Arnold. :lol:
