73 Intake for stock hood
Hi everyone. Building a 383 stroker for my 73. Need an intake that will fit the stock hood. So far only found Edelbrock 2101 performer. Think I'm going to use Quadrajet, though shop is leaning towards EFI.
Seems like a Performer RPM will work with a drop base air cleaner. An RPM Air Gap might on that model. Someone will chime in here about it for sure.
On my '73, I'm running the Holley Contender 300-36. It's the aftermarket version of the early 70s LT-1 high rise intake. I'm running a Holley Street Avenger carb, Holley heat shield, 3" air filter element, 1.5" drop base air cleaner, and a flat billet air cleaner lid. The lid is approximately 1/4" thick above the air filter. The knob that secures the air cleaner lid sticks up about 1/4" above the air cleaner and I have about 1/2" clearance from that knob to the hood.
The outside edge of the air cleaner lid in one spot toward the AC compressor just barely touches the inner hood at times. I can see rub marks. To solve this, I either need a different air cleaner lid that is less than 1/4" thick at the edges and doesn't rise much in the middle, or I need to replace the 5/16" carb gasket that came with the heat shield with a slightly smaller (maybe 1/4") gasket. This setup barely clears the choke plate on the carb. I'd rather have more space between the air cleaner lid and top of the carb but that's as good as I can get with this setup. All in all, it's a tight fit but it runs well. My future plans include EFI and I'll look at different setups then. DC |
Thanks for the input!
:flag:
Originally Posted by DC3
(Post 1584449017)
Originally Posted by CaseyJones
(Post 1584448766)
http://i71.photobucket.com/albums/i1...s/DSCN3383.jpg[/URL] |
That looks awesome! Was concerned about the 2101 being too conservative also. Thanks for the tip regarding the airgap manifold, wondered about that.
Fuel injection for a 73?
Anyone install a fuel injection on a small block, that fits under the stock 73 hood that they like?
Originally Posted by Franks73
(Post 1584463035)
