WTT: Pro-touring 69 Camaro for '12 or '13 Z06 or ZR1
WTT: my pro-touring 1969 Camaro for your late model (prefer 2012 or 2013 but not necessary) Z06 or ZR1 and cash.
A car still under warranty is desired. Willing to trade with dealers also. To place an approximate value on my car, I refer you to recent Barrett Jackson auctions. Cars similar to mine have sold between $125,000 and $165,000. It's a total frame off rebuild. I have hundreds of detailed pictures documenting the entire process of the build and the car was built by one of the best shops in the country. Call or text Bryan at 760-458-3606 LS2 engine (stroker 402ci, 580hp crank) Tremec T-56 Magnum 6-speed tranny Detroit Speed (DSE) hydroformed front subframe with: • Hydroformed Framerails • Stamped Crossmembers • Tubular Upper and Lower Control Arms • Coilover Shocks • Coilover Spring • Power Rack and Pinion Steering • Splined Anti-Roll Bar • C6 Steering Knuckles and Bearing Packs DSE rear QUADRALink DSE adjustable rear anti-roll bar kit DSE/Moser Ford 9" rear end Ron Davis radiator Wilwood 13" brakes; 6-piston front 4-piston rear DSE weld in subframe connectors DSE transmission crossmember (welded into body for additional rigidity) DSE four-point roll cage (welded into body, not bolted) DSE selectra speed-wiper kit DSE electric RS headlight door kit DSE mini-tubs DSE roll cage DSE dash insert Flaming River tilt steering column Momo steering wheel Magnaflow exhaust Vintage Air AC/Front Runner Katech satin black valve covers Katech coil relocation kit Fikse FM5 wheels; 9" front, 11" rear Nitto NT-555 tires; 295/45 rear, 265/35 front Valencia Orange color (BASF 3-stage paint) Recaro Specialist cloth seats Black Porche carpeted interior (forgot the brand but Porche fanatics go nuts over it :)) Sueded headliner AutoMeter carbon fiber gauges (tach, speedo, oil pressure, water, fuel, volts) G-Force four-point racing harness for seat belts Clayton Machine Works pedals, window cranks and door handles Rick's stainless steel tank Dynamat sound deadner throughout Loaded with billet parts such as Marquez Design billet taillights and running lights, Billet Specialties hood hinges, etc.... I've left out a lot of stuff and I'll try and update the parts list later... Tucked, narrowed and painted front bumper Ringbrothers billet black powdercoated hood hinges Ringbrothers billet clutch fluid reservoir Ringbrothers billet sill plates Marquez design billet door strikers Marquez design billet side marker bezels Marquez design billet jamb vents Marquez design front valence Marquez design adjustable door stops Billet Specialties billet rear battery mount America Autowire http://i29.photobucket.com/albums/c2...08-1015561.jpg http://i29.photobucket.com/albums/c2...510_121654.jpg http://i29.photobucket.com/albums/c2...510_121708.jpg http://i29.photobucket.com/albums/c2...510_121719.jpghttp://i29.photobucket.com/albums/c2...510_121730.jpghttp://i29.photobucket.com/albums/c2...510_121745.jpghttp://i29.photobucket.com/albums/c2...510_121755.jpghttp://i29.photobucket.com/albums/c2...510_121804.jpghttp://i29.photobucket.com/albums/c2...510_121812.jpghttp://i29.photobucket.com/albums/c2...510_121826.jpg |
Here's a video of Ernie Mena of Westech Performance dyno tuning the car.
http://i29.photobucket.com/albums/c2...ro/Image48.jpg |
A couple more vids.
Wow, that's a beauty!
Thanks
Love pro touring rides.
Good luck with your quest and nice ride. :cool: |
You're crazy, that thing's twice as cool as either car you're seeking.
Originally Posted by Digital Disaster
(Post 1584427446)
I'd be interested. Does it have A/C? Can the cage come out? Are you in AZ?
Originally Posted by USCGREEL
(Post 1584446986)
Cage is welded into the body at four spots. I guess you could remove it. There are several things that add to the rigidity of the car. The cage is one of them. The DSE transmission crossmember is another. I wouldn't remove it but it's your car. :) http://www.detroitspeed.com/1967-196...ossmember.html I live in north Phoenix. |
(Post 1584446986)
The cage, like many parts of the car, is a DSE cage. It has a "removable cross-bar with CNC machined stainless steel clevis and quick-pins. The exclusive DSE design follows the interior lines of the car. It does not interfere with the interior comfort and packages close to the headliner and back window glass." FWIW, I view the cage (any cage really) as a cranium crusher. I have never driven the car with a passenger in the back seat. http://www.detroitspeed.com/1967-196...roll-cage.html |
That is one sick PT camaro !! Having DSE's full suspension is a dream of mine ! I know it corners like its on rails . I would just have to hang on to that beast. are you on Pro-Touring.com ?
Originally Posted by 08velocity
(Post 1584447778)
I mostly hang out on Lat-g. |
I'm with the others... gorgeous car.
What are you asking for it outright? |
Originally Posted by The Patch
(Post 1584425462)
Originally Posted by Drewstein
(Post 1584451776)
A green Camaro just like yours went across the block for $72k so not sure where you're getting your numbers. It even had an LS7...
http://www.barrett-jackson.com/appli...n=1260&aid=443 http://www.barrett-jackson.com/appli...n=1050&aid=466 http://www.barrett-jackson.com/appli...n=1014&aid=466 http://www.barrett-jackson.com/appli...n=1072&aid=466 http://www.barrett-jackson.com/appli...n=1083&aid=466 http://www.barrett-jackson.com/appli...n=1329&aid=466 |
Hot car.
GLWS. :thumbs: |
Thanks
