Lots of breat GO-FAST parts..Trick Flow T&D Comp Edelbrock Nitrous outlet...
Trick flow LSX 245 6-bolt heads
New 2.100” Ferrea stainless intake valves, 1.6”stainless exhaust valves. Upgraded with PAC valve springs and titanium retainers Ductile iron seats which are great for high power cars for durability and transferring heat out of the valve. Can be used on a 4-bolt block. 70cc combustion chambers, 245cc intake, 80cc exhaust, cathedral port, bronze guides, minimum bore size is 4.030” Flow bench data: http://static.trickflow.com/global/i...0245%20lsx.pdf Have 3000.00 in these heads. 2 intake ports had to be epoxied due to too much pushrod clearance work. New rockers moved the pushrod over, so there is no clearance issue. Pressure tested to 30psi on the car with an F2 supercharger. 2100.00 Rockers are T&D shaft-mount 1.7 rockers with offset intakes to center the pushrods in the bore. Also have the stock, centered pushrod rockers 750.00 Cam is a custom ground blower cam 239/247 114+4 .620/.632 lift, made using HUC lobes. These lobes are designed for stable operation up to 8kRPM. 275.00 Lifters: Comp Cams Race short travel link bar lifters with 1kmi. 550.00 new, 300.00 plus shipping Intake: Edelbrock Victor Jr. Intake manifold. Custom powder coated candy blue, custom billet mounts for the modified fuel rails. 6061 elbow for 90mm TB. Direct port nitrous done personally by Dave Vassar, the owner of nitrous outlet. Includes jet sizes from 150-250hp xxx.00. Add xxx for solenoids. Also includes front fuel crossover line and fittings. 1100.00 plus shipping. http://www.bradbury.org/bret/sale/vic-1.jpg http://www.bradbury.org/bret/sale/vic-2.jpg http://www.bradbury.org/bret/sale/vic-3.jpg http://www.bradbury.org/bret/sale/rockers-1.jpg Custom stand-alone fuel system designed by me, built by Nitrous Outlet. Designed to have greater capacity. Has regulator, gauge, filter, bleeder with return to prevent any fuel delay at the solenoid. It bolts in place of the battery and the battery must be relocated, or this can be mounted in back somewhere. 750.00 shipped. Will take a few days to remove from the car, drain and air out so I can ship it. http://www.bradbury.org/bret/sale/stand-alone1.jpg http://www.bradbury.org/bret/sale/stand-alone2.jpg RPS Billet Triple disc clutch with HD pressure plate. SOLD Will make a package deal. I’ll post pics soon. Just wanted to get the ad up. PM, Text or Email. Nine seven two 741-7457 |
Bump for my lsx idol
Thanks Tiredude. :)
How would that cam work on nitrous ?
Originally Posted by igtabg1
(Post 1584349276)
clutch sold. :thumbs:
sale pending on the heads, rockers and lifters......
Sale still pending, but if I don't hear from them soon I'll remove the pending status.
sending pm about the intake.
Originally Posted by CUZIWIN
(Post 1584441484)
