[FS] 2008 Black Twin Turbo ZO6
2008 TT Z06 with 16,123 original miles. Black exterior with black/silver interior. Car has never been wrecked or abused and has been garage kept. Car made 930rwhp on springs and 1063rwhp with boost controller on 93 octane pump gas. Possible partial trades may be entertained with cash difference. Also may change wheels/tires to original chrome ZO6 combo for less or remove aftermarket audio for the factory bose system. $72,500.00 reasonable offers welcome
EXTERIOR ZR1 front splitter and rear spoiler painted black to match ca rock guards painted black to match black out kit HID 6k lights black mesh front grille lowered in front and rear Hawk brake pads WCC 946 ext wheels 19/9.5 fronts Nitto tires and 20/12 rears Nitto 555r drag radial tires INTERIOR carbon fiber console trim ring HID 6k lights (complete) Kenwood double din with navigation JL Audio stealth box JL Audio C5 components JL Audio HD amps Optima battery DP black wrinkle coat extinguisher with billet brackets DP black wrinkle coat co2 bottle with billet brackets AMS 1000 boost controller Auto Meter nexus boost, air/fuel and fuel pressure gauges on pillar pod mile2wild switch for exhaust K40 radar/laser jammer DRIVETRAIN RHS lsx aluminum block 427ci by Proline Racing Engines 9.25:1 compression Calles Dragon Slayer crank Oliver 6.125 rods Diamond CC pistons Total Seal CS rings ARP bolts Comp Cams custom grind cam Morel lifters Smith Brothers push rods Trick Flow 245cc aluminum heads with cometic gaskets NGK tr-10 plugs Katech valve covers with relocated coil packs ACCEL custom wires FAST 102 intake with 102 Ncik Williams tb both port matched by JJ Formato ET Performance crank vent kit ARE dry sump system RSI triple pump fuel system FIC id1000 injectors FAST billet fuel rails and Aeromotive fuel regulator AEM dry flow air filters Pressurized Solutions custom TT kit with 3 core IC, GTO manifolds, Turbonetics 76mm dbb turbos, JGS 40mm wastegates, B&B cat back exhaust (manifold & tubing coated) Ron Davis radiator Tick Performance adjustable master cylinder with remote bleeder SFI bullet proof bell housing RPS triple disk clutch MGW short throw shifter HP Tuners custom tuning done @ Pressurized Solutions in Haleyville, AL I'm sure they may be more I've overlooked. Please feel free to pm or post up any questions u may have. http://i1298.photobucket.com/albums/...ps477ff487.jpg http://i1298.photobucket.com/albums/...ps69cb889e.jpg http://i1298.photobucket.com/albums/...ps477c399e.jpg http://i1298.photobucket.com/albums/...ps08e35105.jpg http://i1298.photobucket.com/albums/...ps3b8f912b.jpg http://i1298.photobucket.com/albums/...s16ff11d6.jpeg http://i1298.photobucket.com/albums/...s3bf74ded.jpeg |
Original Owner?
Miles on the build? What's next? :) |
I bought the car with about 1500 miles on it....it was a Lingenfelter 616 car from Mobile, AL. Build has about 4,000 miles on it and runs like a top.
May wait on the 2014 Z's or possibly do a pro touring '69 camaro w/ TT LS7 |
Damn...very Nice:thumbs:!
can't see the pictures, please email to elscullard@hotmail.com in and outside of you can.
TTT for a nice build and lots of power! |
Originally Posted by Philly-Goat
(Post 1584304500)
Originally Posted by C5 Scully
(Post 1584306531)
WOW! That's a Beautiful Car!
Good luck with the sale and bump to the top for you! :cheers: |
Proline and Pressurized Solutions - someone has too much money. ;)
Great looking car! I'm sure it's a blast to drive. Best of luck! |
Originally Posted by Turbo2L
(Post 1584317173)
Great looking car! I'm sure it's a blast to drive. Best of luck! Haha, u know ur shops! But u get what u pay for, and this car is evidence of that for sure.... |
this car is a twin to my tt car that just got totaled by a lady who didn't understand how a stop sign worked.
I had the rsi triple in mine as well. Do you run into pump wine and pump cavitation issues due to fuel heat? I set my rsi system up custom, and had 2 pumps on, and the third was on a separate switch. Just curious if anyone had to troubleshoot all the problems I did with their fuel system. When did you put the rsi system in? Date? Thanks, Brandon |
ps, how have you not upgraded the brakes? ;)
can you post up the power graph also? Id like to see how the turbos behave.
Originally Posted by irun4cops
(Post 1584322025)
I had the rsi triple in mine as well. Do you run into pump wine and pump cavitation issues due to fuel heat? I set my rsi system up custom, and had 2 pumps on, and the third was on a separate switch. Just curious if anyone had to troubleshoot all the problems I did with their fuel system. When did you put the rsi system in? Date? Thanks, Brandon the RSI system is abt a year old and have never had a cavatation problem with it, and I've been on 4-6 hour trips each way. Been very pleased with the triple pump set up.
(Post 1584322028)
(Post 1584322124)
That's my worry that I would have to go with different turbos. I was running garret gt30s on my other car I think and it kept making more power to 7000rpm, but they spooled almost instantly.
car is all u can handle with the drag radials on jus the springs, much more on the street would make it a pedal fest. there's no lack of power with this set up by any means. I've never even turned on the co2 and boost controller on the street, no need really.
guess id have to come check it out. You are in alabama right?
yes....north Alabama
Are you going to be around tomorrow, if by some miracle it doesn't rain?
I should be in the area most of the day....
