Need your tilt-tele steering column rebuilt? Tracdogg2 is your answer
Tonight, on his day off mind you, Mike (Tracdogg2) came over to my house to check out my 1958 Bel-air and my 1970 Chevelle. I mentioned to him that we were having a little bit of trouble with the horn and telescoping mechanisms on my steering column. He said give me a phillips screwdriver and I can fix it. Luckily I had all the parts we needed ready to go, as you can tell by my previous posts. He took a couple hours on his day off and helped us remedy the issues. Now it tilts, telescopes, and works the horn like it is brand new. He even installed a new turn signal switch.
Moral of the story is, if you need some steering column R&R, give Mike a call. He can take these things apart and reassemble them with his eyes closed. |
Originally Posted by chstitans42
(Post 1584284995)
Moral of the story is, if you need some steering column R&R, give Mike a call. He can take these things apart and reassemble them with his eyes closed. Rogman |
You better be careful. Trackdogg2 might suffer the same fate as Gary and Lars.
Jim |
