Kwik-Lift owners, what length are your rails set at???
WITHOUT scraping the spoiler?
13' 3" or 14' or 14' 9" Thanks! |
I've only had mine a few days but set them at the longest length. My C5 isn't lowered and doesn't scrape.
Mine is set at the middle position. My cars are stock height and don't scrape pulling on the ramps,
You should also watch at the far end too. The main supports are tall enough they will hit the air dam. I use a block to set how far forward I can pull it without hitting. Then it is easy to pull up to the block and have it positioned in the right spot every time. |
Originally Posted by Zorlac
(Post 1584264584)
Middle position here too.. No issues.
