please school me on A4
So the issue where the trans hesitates to shift from 2 to 3 is getting worse. It hangs longer and longer over time. Going to a performance shop tomorrow and would like to know what the common upgrades are to make the A4 more sturdy.
I know I will stick out out like a sore thumb as a noob but want to at least save a little face with some solid advice. Thank u all in advance. |
Originally Posted by NotAnExpert
(Post 1584240800)
I know I will stick out out like a sore thumb as a noob but want to at least save a little face with some solid advice. Thank u all in advance. Boosting the line pressure, either by PCM programming or installing a Trans-Go shift kit, may temporarily improve shift firmness in a worn transmission. Common upgrades will require a unit rebuild, with added clutches and larger servos. Check RPM Transmissions, a Forum vendor, for their available rebuilds in various stage level upgrades. |
If you have not already done this, I would first do a filter and fluid change, make sure the fluid level is correct and that the new filter is vacuum tight before installing. The new filter can be checked by putting a mild vacuum on the outlet with your mouth and blocking the inlet with your hand.
There are some old posts that indicate transmission malfunctions were caused by a defective filter or low transmission fluid level. If the existing fluid has a burned smell, the fluid should be changed twice or more because a drain and refill replaces only about half the total amount of fluid in the transmissio. About half is held in the torque converter and other spaces that don't drain by gravity. Alternative to gravity draining and refill, the transmission can be flushed by a shop that has the equipment to do so. That proceedure replaces essentially all the fluid in the transmission. |
