2007 Corvette 440 ls7 widebooty $35k
Thinking of selling my 2007 corvette with a LME 440 LS7. Wanting to build a garage, so I would rather sell the car and use the cash from the car, instead of having to get a loan. Interior is in perfect shape. Exterior is in good shape for a 6 year old car. The only problem I have with the car, is every now and then it makes a noise when taking off from a dead stop. A mechanic told me to bleed the clutch to see if that would fix it, just haven't had time to try it. Doesn't do it all the time, just every now and then. Pretty sure the sound is coming from the slave cylinder, but not 100% sure. Only does it from a dead stop, once moving, never makes a noise. Also, I have a complete Z06 front end and a set of 360 forged wheels I can add in for more money. Asking 35k or best offer. Car is located in Birmingham, AL. It has 49k miles on the body.
Exterior Has the OEM widebody rear quarters with the brake ducts. All lights have been tinted. 5% window tint Z06 Brakes all the way around, powder coated dark silver Sits on dark gray Z06 Wheels Interior Alcantara suede A-pillars Alcantara suede and leather console 08+ radio bezel MGW shifter Derlin shift knob Z06 seats Performance LME built forged 440ci LS7 -New GM LS7 block -Callies forged crankshaft 4.1" stroke -58x reluctor wheel -Callies 6.125" forged rods -ARP 2000 bolts -Wiseco custom 4.135" forged pistons -Clevite bearings -Arp studs -Comp cams LS7 lifters -Comp cam XER lobes .645-.672 @ 248-260 -Roll master double roller timing chain -Melling high volume oil pump -Trick Flow 235cc heads -FAST 92mm intake ported by LME, smoothed and painted black -Black mezeiere electric water pump -1 7/8 Kooks headers -Catless mids -Corsa 3" Exhaust -Katech tensioner Suspension Lowered on stock bolts QA1 rear shocks Z06 front and rear sway bars HD links Drivetrain LMR built T56 Ram twin disk clutch Z06 battery relocate to trunk Braille lithium ion battery http://i143.photobucket.com/albums/r...psc95725a1.jpg http://i143.photobucket.com/albums/r...ps15472be6.jpg http://i143.photobucket.com/albums/r...ps48b05ac4.jpg http://i143.photobucket.com/albums/r...ps48b05ac4.jpg http://i143.photobucket.com/albums/r...ps873a196c.jpg782/003_zps873a196c.jpg[/IMG] http://i143.photobucket.com/albums/r...ps873a196c.jpg http://i143.photobucket.com/albums/r...ps3a32801c.jpg Here is a picture with the 360 Forged wheels http://i143.photobucket.com/albums/r...ps53365b0d.jpg http://i143.photobucket.com/albums/r...ps57d2a06b.jpg http://i143.photobucket.com/albums/r...ps27e67640.jpg http://i143.photobucket.com/albums/r...psaa5b9431.jpg http://i143.photobucket.com/albums/r...ps2268a74e.jpg http://i143.photobucket.com/albums/r...ps02802399.jpg |
what did it make for power and I am interested in that z06 front end if you want to sell.
Originally Posted by hammert85
(Post 1584223800)
could you post some pictures of the engine and front end plz
Added a few more pictures to the first post.
Nice car for a nice price. As for the sound it makes on take off, it's probably just clutch chatter. Try doing a 2nd gear 5k rpm clutch dump to burn off any glaze. I hear about it a lot with performance clutches, though those are usually single disc, not twin.
didn't you just buy this car like 2 months ago ?
Originally Posted by bikera5751
(Post 1584234752)
do you know what compression the engine is running?
Tire size front and rear, Compression. Do you know who built motor? Can you post Dyno Sheet?
Compression is 11.8:1. Can't remember tire sizes off the top of my head. I know the backs are 345, but not sure about the front. I don't have a dyno sheet, but I can take it to my local dyno and get some numbers. LME built the motor.
Bump. Going to keep it up for sale for one more week, then I'm going to part it out and put it back stock.
is the 35k price tag including the Zo6 front end>? if not, then what is the total price?
Originally Posted by xpzeed
(Post 1584259813)
This car's first owner lives in Montgomery Tx.
Sale pending, deposit received.
To the new owner, I do not have his contact info and he does not post on the CF. the car has always had the 360 wheels on it from the get go and you can look up history from the owner before this owner on ls1tech.com
The car was sold for 35k with the 360s. On ls1tech. This is about the most I know on the car. |
Yea... ditto on the noise being a little clutch chatter. My red GTO does it too with an aftermarket clutch. Usually in the morning when the car is cold. Sounds like I have bad brakes when I first engage the clutch. Figured it's glazed a little since I'm perhaps too easy on it.
Just now saw this. I took the car to Speed Inc to get a new clutch. After it was apart they found that the torque tube input shaft had some damage on it. I had them replace the clutch with it anyway just to be safe. I am very happy with the purchase still. Great seller!
