TPI intake ducting
I've had a TPIS miniram setup on my '80 for a while now with a slinky hose duckting to the air filter mounted in front of the air con.
Has anyone got or know of a better setup. I'm thinking about cutting a hole beside the radiator to get the air filter in front of the radiator. or runnuing through the origanal ducting over the radiator & into an airbox / filter. fyi, the clutch fan is gone, I'm running a couple thermo's |
we need to see pictures, thats a swap I'm thinking about
Get to one of my sites below, maybe have to copy/paste, and there are pix of how I did my up/over air induction....
:D:willy: |
Originally Posted by mrvette
(Post 1584201781)
DC |
Originally Posted by DC3
(Post 1584202662)
You flipped your hood to open bassackwards. Any way to run your type of setup with a normal hood?
DC |
I run a air filter in front of the rad by notching the top of the rad shroud and shorting the hood prop to restrict the opening. The filter sits about 4 inches above the oil cooler so it don't get too much water splash.
The air feed is 4 inch diameter tubing that is flattened oval where it goes over the rad. I don't have FI but this should work the same as my carb system cold air feed. http://img.photobucket.com/albums/v1...1/IMG_4108.jpg http://img.photobucket.com/albums/v1...1/IMG_0020.jpg |
