fan shroud position
Hello -
I haven't been on the forum for quite a while. I have recently begun working on my 1978 Silver Anniversary Vette again. We are getting ready to install the front clip. The instructions that I have say that the distance from the front lip of the hood surround to the rear hing bolt should be 43". Ironically, the is the distance to the front hinge bolt. The fan is also hitting the shroud. Go Figure. If I lower the front frame extensions the fan shroud tilts away from the fan and it no longer hits. But then the nose of the front clip is too low. I am going to check the motor mounts but the measurement to the hinge bolt won't be affected by that. Any help would be appreciated. Thanks. |
I just hung one on a 77... I'm sure I can help you.. Do you have any pictures I'll try to help you.
That would be great. I am trying to upload the images now. Thanks!
The images are way too large to upload on this forum. I'll find another way to post them.
The 43" figure comes from Eckler's (at least, that's where I saw it first years ago). It's ballpark but I used it to success on my '68. If memory serves, it's to the center of the first hood hinge bolt, not the second.
If the fan is hitting the shroud, and the shroud is correctly installed, you will probably need to reposition/shim the radiator support. :thumbs: |
Originally Posted by 4rensic22
(Post 1584192695)
Open the picture in Microsoft Paint.. then click on re-size. change this to 25 percent on width and height and save... Or when you have it open in paint, hit the Control and W key at the same time. A menu will open to re-size. Change the size (again to 25 percent), save and upload.. :D Here is a link to the front we just put on.. https://www.facebook.com/media/set/?...6912924&type=3 You'll learn a trick or two there.. Like how to install a front end without screws or rivets! before https://fbcdn-sphotos-h-a.akamaihd.n...89001264_n.jpg After https://fbcdn-sphotos-d-a.akamaihd.n...37545995_n.jpg Willcox :thumbs: |
My fan is hitting the shroud on mine as well. Tried adjusting the shroud with no luck. Still hits. I will be watching this tread pretty close.
Originally Posted by 1973 Vette
(Post 1584202827)
:ack: |
Originally Posted by mrvette
(Post 1584205085)
Bet your engine mounts are bad......maybe trans in rear also???
:ack: |
Originally Posted by Willcox Corvette
(Post 1584200380)
Where do you have them hosted? just post that link.. If you can't upload them anywhere..
