Front licencse plate bracket
Does anybody know where I can get a nice looking front bracket, for C6.
Originally Posted by R&L's C6
(Post 1584175124)
We have them in stock and ready to ship :cheers:
http://www.topflightrepro.com/corvet...brackets.shtml |
I made mine with misc. parts I had in the garage. No holes were drilled or tape used.
http://i139.photobucket.com/albums/q...iscauto004.jpg |
(Post 1584175124)
:thumbs: If you are going to get one this is the best out there.
Originally Posted by Top Flight Reproductions
(Post 1584175155)
Another vote for Top Flight!!
:iagree: If you have to run a front tag, this is the one!:D
Front License Plate
Take a look at the 'Show n Go' License Plate Frame. I put the remote controlled one on my new C6 and really like it.
http://www.amazon.com/s/?ie=UTF8&key...l_7hh2i79d28_b |
i live in pa., thank god i don't need a front bracket for my car. THOSE THINGS ARE REAL UGLY. i think i would get the motorized one, no doubt. if i had to pay 500 to hide it, i would. sorry guy's, jmo.:ack:
Originally Posted by Geometrix
(Post 1584175853)
Made two little angle brackets for the top of the plate. I mounted them at the top of the grille (sandwiched the grill between the bracket and bracket backing plate....no grille damage or holes to drill). I have a small aluminum angle bracket at the bottom attached to the license plate and body with double foam tape...license frame is close to, but not touching the body (again, no holes or damage). This angles the plate back under the body overhang at the top with the bottom overhanging the body slightly at the bottom. Looks good (as good as a front plate can) and better than the available brackets IMO. Cost wasn't really a factor, just didn't like what was available.
I just installed the one from Zip. IMO the ones that put the plate right square in the center look awful. The Zip one is a little offset to the driver's side, and really low. And, it is very, very easy to remove and put back on if you want to.
http://i302.photobucket.com/albums/n...mailer/Ft7.jpg
I have Show-n Go and as you can see I keep it tucked under, most of the time. If I get stopped, only happned once I say just washed the car and forgot to put it out. :hide: I don't like it for the reason the car is so low it hits all the time, speed bumps, drive ways also the motor is weak and a little dirt on it and it doesn't move.:ack: |
Originally Posted by John 511
(Post 1584175101)
check with your state -- here in Tx they just made fold-aways illegal.
I use a Top Flight -- good product |
Mine from Zip is not a fold-away. It is held on by two detents and pulls off easily.
Originally Posted by Don-Vette
(Post 1584175576)
