****** C5 Halo LED Tails @ JWM- SHIPS FREE! *UPDATE YOUR REAR TODAY*
Update the look of your C5 with our led tails. These are brighter and just look better than the OEM sets. See below for more options http://i162.photobucket.com/albums/t.../HALOTails.jpg http://i162.photobucket.com/albums/t...halotails2.jpg http://i162.photobucket.com/albums/t...Halotails3.jpg These LED lights come with everything you need to install. Simply unscrew your old lights and install these. Everything is plug n play. These LED Halo tails are brighter than stock lights which increases visibility and safety. This includes 4 tail lights for a complete set. 28 high powered leds plus the halo rings $255 shipped for non modifed sets ** STANDARD Non modded sets function just like the stock lights only brighter. When you brake the lights get brighter to let others know you're slowing down. The halo ring around the outside along with the inside leds are lit when the lights are on. Standard Halo Mod OPTION** Add $35 to your order for this mod I personally think this is a safer lighting arrangement as there is an intensity change in the original/stock halo rather than the separation of lights, like in the mod. No question really if you're on the brakes when the light has been modded. When your lights or fogs are on the halo around the outside is the only part of the light that comes on. When you brake or use your turn signal the inside leds (28 of them) comes on to let others know. If you are braking without the lights or fogs on only the inside portion (28 leds) lights up. Trust me they're bright! With this mod the halo portion you see in the above pic is lit. When you press the brakes the whole light comes alive like the pic below. This mod takes us approx 5-7 business days. LED Halo OPTION ** This mod replaces the halo ring around the outside of each tail with our flex led strips.This mod actually adds a little brightness to the already super bright halos. This option is perfect for those that run tinted lenses. Add $145 for this. They still function the same. This mod takes additional time to complete. Expect 10-18 days. New LED Halo on the left and the normal halo on the right http://i162.photobucket.com/albums/t...DHalos2014.jpg WARRANTY See full warranty info on our site |
FAQ 1. Will these tail lights cause hyperflashing? Sometimes with modded sets they hyperflash. Some need it most don't. I usually suggest trying them out before buying the hyperflash harness. It's not common. 2. Will they work with sequential flashers? They work great with the halos
Originally Posted by clif
(Post 1577557913)
Yes, I have the sequential mod with my LED tinted lights:
Please see post 1 under each option. |
I have a complicated question......the dealer I bought one of my vettes at which is a 98 coupe installed one of your original halos, I had hyper flash and then bought one of the harness flash units, but only one side flashes in a reduced rate, the other side, right side, still hyper flashes. Any thoughts??
Hard to say without troubleshooting. I'd look at all connections and make sure they're solid. You might have an electrical issue somewhere. The harness usually fixes any hyperflashing. You might pull that and inspect it too.
Can anything similar be done with Euro lamps?
6/13 bump for the JWM customers
We'll be at the NCCO show in Norman OK today. Stop by if you are in the area!
6/15 bump. It was nice meeting some of you at the NCCO show in Norman, OK today!
All current orders processed
Let's update the rear of those C5's
ttt
Just so everyone knows the actual wait times for the modded led halos is at least a month. I hope to get mine soon. :cheers:
Out the door today. Unfortunately some of the custom mods do take additional time over the estimates. These are a pain to mod and we had more orders than usual.
Blame me. I added to the work load. Looking forward to mine.
Originally Posted by Zorlac
(Post 1584432418)
Wow thanks for the orders this weekend CF members!
Thanks for the weekend orders. We'll be in nice and early tomorrow to process those.
Thanks for the weekend orders. We have 2 sets still available that will be ready around mid week. That's for non-modded and standard halo modded only.
The led strip mod of course takes longer. |
Thanks guys!
