Corvette check list
I have been looking at C2 coupes to fill a hole in my garage.
Every time I come home from looking I remember something I should have looked at. So I came up with a check list. I have it in excel with room on the right to write in comments. Tell me what you think and anything I missed. If anyone wants a copy in excel PM me. Joe ------------------------------------------------------------------------------ Corvette Check List Year: Coupe/Conv Ext. Color Interior Color Vinyl/Leather A/T or M/T Mileage Exterior: Body condition, overall Bumpers, chrome, align Cracks, damage Door hinges Door, hood alignment Head light operation Lighting Paint condition Stainless trim Weatherstrip Tires Wheels Windshield, and windows Wipers Interior: Overall condition Bird Cage Trim tag Vin tag Dash Interior trim pieces Door Panels Seats Rugs Headliner Console Horn Steering wheel Shifter Radio Heater, blower Jack, lug wrench Gauges: Tachometer, Redline Speedometer Odometer Fuel Oil Ammeter Temperature Clock Under car: Chassis, condition, rust Front end bushings, etc. Oil leaks Cross member Underbody Transmission type, leaks Exhaust Rear end ratio Rear end leaks Rear bushings, spring Spare tire & carrier Tires Under hood: Overall appearance Engine: Casting # Pad #'s Date code Cu. In. HP Intake Manifold Carburetor Exhaust Manifolds Radiator & hoses Leaks Battery Fluids Options: P/S P/B P/W A/C Tele Column Tinted Glass Hard Top |
you could add date codes for all the engine components, along with glass dates. also if documentation is important to you. that can be added
yes you forgot bring kevin with you
I might add pulling dip sticks, and oil, rad and m/c caps for a look see. This will give u an idea of how the car was cared for.
Two things I wished I knew when I bought my '66; was that although they looked new, the tires were 14 years old and the battery nearly seven.
Thanks for the suggestions. I made a few changes.
Joe
(Post 1583925902)
Originally Posted by Jud Chapin
(Post 1583928908)
Originally Posted by dahogan
(Post 1583929713)
I added battery. |
One last important thing I'd add would be to drive the car at highway speed.
By the time you check out everything on your check list the car will be out of warrenty. :rofl:
Although I'm not in the market for another car, the check list is great idea. Thanks for the post.
I'm looking for a Chevelle. I took your list and tweaked it a bit. Thanks for sharing :thumbs:
Originally Posted by JoeCool66
(Post 1583937999)
(Post 1583938066)
What year. :bigears
Been look'n but only find clones... |
(Post 1583938726)
70 SS, 4 speed. Could be NOM but looks original. Would prefer one that needs a little love to bring it back.
(Post 1583938859)
Can't help you on a 70 SS. All I know is 69 to 72 cars are full of clones. Read up on Chevelle.com and good luck
...send in the clones. yep, already there. Certainly no expert but at least I know some questions ask and things to check. If I find one that's a maybe I'll ask the Chevelle forum for a look see (like I would do here). thanks. |
(Post 1583938880)
thanks. |
