Opinions Please!
I am looking into buying some new outside 'A' pillars from RPI, as mine are stained from bird sh*t or whatever. I was wondering, as I am going with the full painted ones, should I order body color (DSOM) or the gloss black to maintain the stock appearance? :willy:
Any pictures of y'alls vettes with body colored 'A' pillars would be a great help. Thanks in advance :thumbs: |
Stock appearance in my opinion, but that's just me....:thumbs:
:iagree:
Originally Posted by 6893Vette
(Post 1583925958)
I agree with the above. Stock looks good. :thumbs:
The body colored ones look out of place in my opinion.
Originally Posted by SEVINN
(Post 1583926308)
Gloss black! Also tie in perfectly with window tint and glass top if you have it.
if you're not going with something like carbon fiber, why not just take off yours, sand them then paint them. If they come out bad, then spend the money..... A can of spray paint is under $10, no big deal.....
Originally Posted by vig1116
(Post 1583927103)
I had the carbon fiber ones on my c5 stock on my C6, but I agree with the last two post. If you plan to remove them and install new ones, I would get some black paint either semi to match the original or gloss and also if you go gloss apply a few coats of clear and then buff them.
Not trying to stop you from buying from RPI Design, as Josh does top quality work and either way body color or gloss black they will be quality pieces. |
Should run you about $100 to remove your pillars and have a body shop do them perfectly.
Originally Posted by gp56
(Post 1583927239)
(Post 1583927239)
Might try to paint them on the car. |
(Post 1583926889)
(Post 1583927103)
(Post 1583927239)
Stock.......
Originally Posted by Brockman66
(Post 1583927701)
My windows aren't tinted. I'm not a fan of the tinted look. I do , however, have the glass top. So, I guess you're right. It would tie into the whole scheme.
Can't afford to have the car out of commission if I fudge them up. It's a DD so it needs to be drivable at all times. As stated above the car is a DD. I'm not to sure how long it would take a body shop to do this, but I drive the car everyday to work, so that's kinda out of the question. Great suggestion though, I hadn't thought of that. |
