Shifter has play after Clutch install
My shifter has a lot of side to side play in it even while in gear, and it's hard to get into second at times. It just feels loose and muddy for lack of a better term. Its a 2001 Z06. Never did this before. I just had a shop install a Mcleod twin disc RST so the clutch is not the issue. I am thinking maybe the shift linkage from the shifter in the console itself may be loose. Anyone that can point me in the right direction I would greatly appreciate it. I did a search, but got nothing that can help my exact situation. Thanks in advance guys.
And before someone says take it back to the shop, they are a little ways away and if it's an easy fix I'd prefer to do it myself instead of drive all the way to Daytona. |
Originally Posted by Wood81
(Post 1583903696)
So it's fairly easy fix?
(Post 1583904249)
Originally Posted by fisher auto
(Post 1583904268)
Yes have to pull the console out to gain access but not really a big deal. Should be the problem!:thumbs:
(Post 1583904268)
(Post 1583904352)
Another quick question... Is there a link with pictures? I know how to get the console off but want to make sure I tighten the right bolts up.
This was exactly the problem, it works great now. Thanks!
(Post 1583909624)
Ugh, here we go again. I got on the highway yesterday and noticed that it's tough to get into 6th now instead of 2nd. 2nd still sometimes is tough too, about 5% of the time. Is there a way to align the shifter back to stock specs? Like I said before there were no issues what so ever with shifting before I had the clutch install. Is there some way to measure where dead center is on the shifter? I know that it's causing the problem, my transmission only has 30 ish thousand miles on it and has never been abused. I may change the fluid too, would going to synthetic trans fluid help the longevity of it at all?
shifter alignment video here
there is a shifter alignment video here. hope it helps you
http://forums.corvetteforum.com/auto...id-change.html |
Thanks, I will try it again.
