Originally Posted by FrankTank
(Post 1583934649)
Thanks guys :rock: .. Clutch is in great shape I was told so not going to replace :cheers: Trans guy is going through every part of the tranny Tuesday should have the car back end of the week unless parts are not in stock
:cheers: DH |
Congrats Frank. I was hoping u wouldn't get rid of your freshly fixed Z !
Update: Well after going through the Trans more in depth of course yes the Synchros are bad, and I was told several other components (forks) as well as the culprit that started the whole thing, the Rear output bearing
Unfortunately now GM has said they are only willing to cover half the repair in parts and labor.. my options are Option 1- a brand new GM stock Trans Option 2- they will cover half the labor and cost of RPM Level IV Tranny. Option 3- rebuild current trans Option 4 - FK this car I am selling it! So option 2 is probably the best route to go... I am still hesitant though and a little gun shy about keeping the car.. can you really blame me? What's to say in 2 months I am not back here posting that my clutch hydros are out,,,, or my ABS Module took a dump... or the spider Gears in the rear end are gone...boom another 3 grand..:ack: I am normally not a sky is falling type guy, but am skeptical after being burned. I am more upset that the car is not reliable in that the Trans failed.. then I am GM not covering it under good will :crazy: Thank you guys again you have been a huge support. I will make a final decision this weekend. |
(Post 1584039540)
Unfortunately now GM has said they are only willing to cover half the repair in parts and labor.. my options are Option 1- a brand new GM stock Trans Option 2- they will cover half the labor and cost of RPM Level IV Tranny. Option 3- rebuild current trans Option 4 - FK this car I am selling it! So option 2 is probably the best route to go... I am still hesitant though and a little gun shy about keeping the car.. can you really blame me? What's to say in 2 months I am not back here posting that my clutch hydros are out,,,, or my ABS Module took a dump... or the spider Gears in the rear end are gone...boom another 3 grand..:ack: I am normally not a sky is falling type guy, but am skeptical after being burned. I am more upset that the car is not reliable in that the Trans failed.. then I am GM not covering it under good will :crazy: Thank you guys again you have been a huge support. I will make a final decision this weekend. I would go with Option #2. I had an RPM built tranny in my C5 automatic that help up great with heavy track use !!!! :thumbs: Good luck :thumbs: :cheers: DH |
option 1 or 2 but I read option 1 as no cost to you. ??
I hate to spend money that I don't have. ESPECIALLY, if I am spending money to get back to the original set up. It is a little bit easier (for me) to spend money if there is an upgrade included.
I bought an RPM trans for my Supercharged TBSS after going through two trans. (Stock and then stock rebuilt.) I would go for option 2! :cheers: I think that it is safe to say, we all feel your pain. |
(Post 1584039540)
Unfortunately now GM has said they are only willing to cover half the repair in parts and labor.. my options are Option 1- a brand new GM stock Trans Option 2- they will cover half the labor and cost of RPM Level IV Tranny. Option 3- rebuild current trans Option 4 - FK this car I am selling it! So option 2 is probably the best route to go... I am still hesitant though and a little gun shy about keeping the car.. can you really blame me? What's to say in 2 months I am not back here posting that my clutch hydros are out,,,, or my ABS Module took a dump... or the spider Gears in the rear end are gone...boom another 3 grand..:ack: I am normally not a sky is falling type guy, but am skeptical after being burned. I am more upset that the car is not reliable in that the Trans failed.. then I am GM not covering it under good will :crazy: Thank you guys again you have been a huge support. I will make a final decision this weekend. If cost is an issue, then I'd go with the least expensive of the options you list, which would probably be 3....which really is option 1. A "brand new" transmission is possibly to have been "rebuilt" anyway. If cost is not a concern to you, then I'd go with 2, which is probably going to be the more costly of the three options you list. |
Originally Posted by Dirty Howie
(Post 1584039650)
Frank
Originally Posted by RedZ4me
(Post 1584039713)
Originally Posted by SSMOKE
(Post 1584039837)
Originally Posted by '06 Quicksilver Z06
(Post 1584039864)
1, 2 or 3, are all acceptable.
(Post 1584039948)
yea I had the Level IV MN6 in my C5 and it was flawless, rock solid. I actually drove from Chicago to Indy back then and waited at RPM shop while they installed a Cartek clutch and the trans, and then drove home that same night :D
I should have been a bit more clear :thumbs: all options (except 4 of course) GM is splitting cost with me. :rock: thanks you guys like I said have been a big support Ricky, actually I had thought that too, however I guess due to the labor of rebuilding the trans itself, then installing it and that having labor with it... The RPM deal works out a bit cheaper since the trans comes all set to throw in the car. A new stock GM trans replacement actually comes out more expensive than the Level IV RPM deal. Looks like a Level IV T56 on RPM website is about 2300 bucks :cheers: Oh, well in that case, I'd go that route instead. :thumbs::cheers: Good luck Frank. |
Holy Gadzooks Batman.......That's what I said to do in the first place. How does the torque tube look Frank? Don't just throw the old one back in until the bushings are looked at. :thumbs:
The original deal was GM was going to pick up 95% of the tab and rebuild the broken part of my trans , now since they are only gonna cover half it makes more since to go the rpm route . This will be my last corvette . I'm not upset GM is not covering me out of warranty ..I'm upset because its not reliable ,, what's next my rear end ? Clutch ? Abs ? Everytime I drive the car I'm wondering what's breaking next
^ a tough state-of-mind to be in with a car...suspect many of us have been there at some time in the past
with a particular vehicle...not an easy decision, especially with high-performance cars. |
Now, I don't personally know the OP (victim), but I'm wondering how hard the car has been driven with all of the problems he's having. I'm on my 5th Vette and have had very few problems with any of them. I hope everything works out for him, though. I hate to see anyone disappointed in my favorite car model. Good luck.
Don't know if tank is original owner. Could have been driven "no mercy style" by another owner. Its so important to do all the research one can when buying a previously owned vehicle.
No issues with either of my vettes. Just a bad fob. Warranty. |
(Post 1583897335)
I am a little scared to do so honestly above 2500.
Originally Posted by JT Metal
(Post 1584042672)
Originally Posted by Gary '09 C6
(Post 1584042366)
Originally Posted by ParisTNDude
(Post 1584042618)
The car has a conservative tune and put down 474rwhp. I know guys with 100 more hp than me who are on stock Trans with no issues
(Post 1584042672)
Originally Posted by Mr. Gizmo
(Post 1584042775)
What kind of noise does it make when you run it through 1st, 2nd, and 3rd gear to 7k rpm in each gear? Do that 5 or 10 times in a row. if it does not break there is not a problem. if something breaks then you have found the problem.
Bad Fob might justify a lemon buyback. |
Tough break Tank.
This is what we get when the bean counters get to buy the parts that go into them. :ack: Tim :cheers: |
Sorry you're having the troubles, regardless of what caused the problems.
Originally Posted by ipmtim
(Post 1584046024)
Tough break Tank.
(Post 1584047069)
(Post 1584047084)
Exactly , at least Kevin went to bat for me and they are covering part of it
Thanks :thumbs: http://forums.corvetteforum.com/c6-z...-knocking.html |
