I've seen Mazda speed 3s fail bone stock and heard about them failing bone stock from locals. That's one I can remember off the top of my head. Others I'm sure you can Google to find.
Originally Posted by LS7 DREW
(Post 1583917037)
Either way, its a manufacturer problem not a "cars fail" problem. Good luck Frank. |
(Post 1583917037)
While I would have preferred not to deal with this on my Z06, Drew has a point. Not every car is perfect may have a weak point somewhere in their design. It is unfortunate, but there are lots of good cars that have some issue. The Z06 isn't the only one that has to deal with it, but at least we have a fix. We can hope that the manufacturer fixes it, otherwise, its up to the owners to foot the bill or sell it and buy something else. Another good example are 911 Turbos, GT2s, and GT3s, which are known to have coolant hoses pop off and dump all of its coolant. Results can be extremely catastrophic. These cars are in the 150k range and can get close to $250k. You may be aware of coolant pipe issues on GT1-block equipped models (GT3, GT2, Turbo), where coolant pipes come apart while driving and the rapid loss of engine coolant can cause spins/crashes at race tracks when slippery coolant sprays all over the rear tires. The problem exists on the GT1 motor because there are a couple coolant pipes in these motors that are not a single cast piece: the larger cast pieces have extruded inlet/outlet tubes that are connected using an adhesive. There is no metal-to-metal friction or press-fit to keep these tubes in place, so after enough heat cycles the adhesive will soften/loosen up and the tube will come out of the cast block (with the hose still attached), resulting in a rapid loss of engine coolant. Regardless of how the vehicle is driven, it seems this problem may eventually effect all 996/997 Turbo, GT2 and GT3 models including the 2010+ GT3 and GT3RS. If you are interested in having us repair the car at our facility, the price to remove and re-install the engine with this repair is approximately $2800 USD. http://sharkwerks.com/porsche/techni...urbo-cars.html |
(Post 1583917037)
the thing that is driving me now (no pun) away from GM and the Z06 is the fact that okay so I addressed the potential problem with the heads, turned it around into a positive, modded and gained some power... moved on, it happens but now, to have the Tranny fail on the same car with no track time and under 30k miles, to me I draw the line.. those are 2 major components with this car I forgave GM for the head debacle, fixed it and moved on. I can't be as forgiving with the car this time around having the Tranny fail. and of course I'll be honest, the timing of everything does have an impact on my decision |
I'd be mad too that you had bad luck with the car, but personally I just see that as a risk of owning a performance car. It sucks that you have an issue with the trans I hope it's a cheaper fix than what your expecting and you can enjoy the car after.
Originally Posted by FrankTank
(Post 1583917230)
Drew, I can understand where you are coming from to a degree, and I would also agree.. every manufacturer of course has cars break and QC problems etc... Ford and Dodge have their cars that have issues too...
(Post 1583917292)
This excuse doesn't quite sit as well with me as I own many performance cars without any kinds of issues like this. I would also agree more if the performance car was being used for its performance like at the track and events like you and I both attend. When being used as a DD I feel for the guy who just finished addressing the "one issue" with the Z06 and a few weeks later has a bad tranny on a car with less than 30K. Performance car should mean better built. Not fall apart quicker. But Ive always been a firm believer of pay to play. The problem comes in when people aren't playing yet they still have to pay. |
I heard from people that the cars have had failures with people just cruising around, I can't remember what they said the weak link was it was like 4yrs ago that I heard about it lol.
My aunt had a similar problem on her cayenne turbo s but luckily it was under warranty. And that's a 100+k suv
Originally Posted by Jawnathin
(Post 1583917190)
There was talk about their rods being a little weak and have snapped when at full boost during low RPM, but I've yet to have an issue with mine. It has been pretty reliable and far less of a money pit than the Z06 has been. There has been issues with owners doing mods but not upgrading the fuel system, causing an engine failure, but that is an owner error.
(Post 1583917292)
Originally Posted by propain
(Post 1583917326)
I would also agree more if the performance car was being used for its performance like at the track and events like you and I both attend. When being used as a DD I feel for the guy who just finished addressing the "one issue" with the Z06 and a few weeks later has a bad tranny on a car with less than 30K. Performance car should mean better built. Not fall apart quicker. But Ive always been a firm believer of pay to play. The problem comes in when people aren't playing yet they still have to pay. Oh well... I'll have to see what happens and go from there. It's ashame because there is so much I do love about the car, looks, power etc. light weight. |
(Post 1583917378)
Thanks man, me too :thumbs:
This is really what has me disappointed and scratching my head...car is not making big power, not tracked (I had actually planned to start tracking it since I fixed the heads) sure the occasional blast on the street or something but thats it. Oh well... I'll have to see what happens and go from there. It's ashame because there is so much I do love about the car, looks, power etc. light weight. My opinion Frank is that you should fix it and keep it. Sorry you have to and honestly its completely unacceptable that you did but your almost there. What give someone else your hard earned money after fixing it. :thumbs: |
(Post 1583917399)
(Post 1583917399)
Tough break, your tranny going at a time like this, or really any time. But you've come this far, seems a shame to fix it, sell it, and let someone else reap the benefits of your efforts. |
(Post 1583917412)
I may have a change of heart and keep it who knows, and believe me...the less emotional part of the brain is telling me the same thing you are....why spend the money and put a brand new trans in the car (or freshly rebuilt one) and then sell it :crazy:
(Post 1583917412)
Originally Posted by z0sicktanner
(Post 1583919109)
if you need help on a trans rebuild hit me up.:thumbs:
(Post 1583919109)
Didn't read all 5 pages but any verdict on the problem?
Originally Posted by Mopar Jimmy
(Post 1583919747)
I don't care what anyone else says Chad, your ok in my book, Tin hat and all. :) You know I'm just busting your stones man, all in good fun! - : )
Originally Posted by CFLZ
(Post 1583905659)
It's all in the engineering. You can see it in the head design down to the windows that will not index properly. I think you would be well served to sell the car and get something with a little better build quality. I was in the same situation a few months ago with my Z and got the car out of my life.
(Post 1583917399)
(Post 1583919109)
Originally Posted by ck9887
(Post 1583919925)
