I've heard that the Mustang Boss 302 is supposed to be built tough. If I hadn't fallen in love with the looks of the Vette I might have gone with a low miles used Boss and supercharged it.
Originally Posted by '06 Quicksilver Z06
(Post 1583896822)
Weren't you having some transmission issues Frank?
On the other hand, it would be a shame if you got the whine fixed and then sold it when that was the last remaining issue. In other words, you would be selling a reliable (?) fun car w/o any issues.
Tough decision either way, hope the whine is something minor/cheap. |
Didn't read the whole post the first time so I'm changing my post. I hope it ends up not being anything too serious.
I'm thinking it has something to do with your transmission Frank.
And that time on the dyno, dialing the tune in, probably didn't help it. |
Originally Posted by Adam_W
(Post 1583900145)
I have nothing useful to add but would like to keep informed of what the cause turns out to be. Im hugely paranoid about my crank bolt since I don't really know how tight I got mine when I put it back in.
Just take it to a shop an diagnos it professionally. have yourself a beer while you wait. I used to get all worked up and freak out over things that pop up and surprise you but when it comes down to it 99% of the time people tend to sweat the small stuff. Stay calm and be happy that you own the most beautiful and one of the most powerful all around vehicles ever made. It's a car. Things break. But.... Not all car break and look this good:) go get it checked out first and make a game plan from there. I'm sure if its major there are plenty of local people that would love to help you out. Good luck.
Originally Posted by Dallasb84
(Post 1583901004)
You -can- get a wrench on the balancer bolt if you just take off the intake tube (the filter to throttle body plastic thingy).
that would tell you if its moderately loose or not anyway. |
Thanks everyone for the replies. I checked the crank bolt earlier after work today and its tight, and I took a look at the pulley etc.. while the car was running and it appears normal, no leakage or anything. When my C5 crank bolt went it was leaking prior obviously the seal
The car is at the Vette shop where I have the work done by trusted mechanic and friend. When I drove it over there, as I was shifting gears , I could hear the pitch of the whine change from gear to gear as they engaged, by change I mean it would stop for a split second as I shifted to the next gear, so I can't see how it is not the trans, unless its something in the rear end or axles or something:crazy: I reved the engine a bit higher in neutral (3500 RPM) and no whine or noise or anything Again gears engage fine (except for R) , clutch and pedal feel are normal no slippage at all. I am hoping to hear something in the next few days
(Post 1583901004)
Yeah it goes that way sometimes. I hope it's something minor. Wouldn't it be great to service the tranny and diff and the noise goes away?
I have a bit of the grinding in first gear at low speed and clunk in the rear end. Gonna change the fluids and hope it goes away.
Originally Posted by FrankTank
(Post 1583902281)
The car is at the Vette shop where I have the work done by trusted mechanic and friend. When I drove it over there, as I was shifting gears , I could hear the pitch of the whine change from gear to gear as they engaged, by change I mean it would stop for a split second as I shifted to the next gear, so I can't see how it is not the trans, unless its something in the rear end or axles or something:crazy: I reved the engine a bit higher in neutral (3500 RPM) and no whine or noise or anything Again gears engage fine (except for R) , clutch and pedal feel are normal no slippage at all. I am hoping to hear something in the next few days I hope you are right and I am wrong, I could be overreacting, but we will see. The bigger issue here is that I just spent a couple grand (actually more) on heads, tune, headers and install not even a month ago.,. had this happened before that I would have just addressed the problem and maybe have sold the car then...but now this comes right on the heals of that. Not to mention I was unlucky enough to also have to purchase all new TI intake valves , so even the heads were about 700 more than most are paying. Thats not my cars fault, but just very shtty luck on my part timing-wise. :ack: I've had at least on person tell me that the ported FAST intake manifold is a bit noisier than stock. But when I first had the work done on the car, I could hear it. Very faint though and can still hear it. What of the above mods do you have? |
Frank
I got my fingers crossed for you :thumbs: :cheers: DH |
Frank, you're in the last lap of a 100 lap race. Don't throw in the towel yet. I know it's easy for me to say...
You've been had one of the coolest heads through all this insanity. Don't reverse plans now. I'll say an automotive prayer for you. This board needs members like you! |
I hope that it all turns out alright.
Did your mechanic not diagnose this a while ago when you car is being serviced? Maybe this was new, but it seems as though from your posts that he knew about it, so I am not sure why he would release the car to you if he knew there were problems (If this is the case). |
Sorry to hear about the woes Frank. I know first hand about problems with the Z06. Let me just say that I bought my 07 with a lot of miles, 67k to be exact. And man did I go through some pain. I think it cost me about 15k to fix the issues, but when you buy AS-IS that's what happens. It was very dis-hearting as I also had to make payments while fixing.
All I can say Frank is whatever the problem was for me I just really didn't like anything else on the market. I sold my Pro-Street car for factory horsepower and I couldn't afford a ZR1. Even now I'm buying parts to make the car look the way I want. Even if you bought another car the money it would take to make it handle and run like the Z would cost as much or more than fixing your car. I guess what I'm trying to say is you may buy another car with more problems, that may not make you feel as good as your Z06. |
(Post 1583902465)
I have a slight whine also, but my heads are ported, as is my intake manifold, I have a Callaway Honker as well, so I know now that mine is due to the increased airflow.
Originally Posted by Dirty Howie
(Post 1583903336)
Frank
Originally Posted by Undy
(Post 1583904060)
Originally Posted by JG853
(Post 1583904192)
Originally Posted by JwT
(Post 1583904290)
All I can say Frank is whatever the problem was for me I just really didn't like anything else on the market. I sold my Pro-Street car for factory horsepower and I couldn't afford a ZR1. Even now I'm buying parts to make the car look the way I want. Even if you bought another car the money it would take to make it handle and run like the Z would cost as much or more than fixing your car. I guess what I'm trying to say is you may buy another car with more problems, that may not make you feel as good as your Z06. ...I know that sounds stupid :lol: but I would be willing to sacrifice performance for long term reliability at this point , and have a factory warranty on a new toy and put this behind me. thanks again everyone for the kind words and support :cheers: |
Best of luck Frank. So sorry to hear of the ongoing problems.
