POLL: Valve Problems
Wish I could or knew how to make a poll. Probably need to pay...
Either way... I say we should create 1 damn thread about the discussion of the exhaust valve problem in the LS7 and make it a sticky. I don't know about anyone else but in my opinion there are way too many concurrent never ending threads about this issue and its mucking up this forum to be honest. Anyone else agree? |
I tried that myself and it went as far as 2 weeks at best. Just too many variables to capture every LS7. On a positive note, POLLS are free. When you make a thread, there should be an aread to check that says "POLL". If you leave it unchecked, your thread will be posted as a simple thread, without a set of poll questions.
As a sidenote for the forum, the moderators here don't listen to feedback when we ask for a thread to be stickied. Good luck with getting anything stickied on this forum lol
Originally Posted by WICKEDFRC
(Post 1583822352)
Originally Posted by icrashevos
(Post 1583822372)
Originally Posted by propain
(Post 1583822322)
Either way... I say we should create 1 damn thread about the discussion of the exhaust valve problem in the LS7 and make it a sticky. I don't know about anyone else but in my opinion there are way too many concurrent never ending threads about this issue and its mucking up this forum to be honest. Anyone else agree? There is no abating the discussion of it. As it increases in frequency, or potential instances of it increase in frequency, so will the discussion of it . Another potential one just about an hour ago. http://forums.corvetteforum.com/c6-z...r-exhaust.html This new one to go along with the one from Bill Dearborn, 1 Bad Burb, Cantevendrive78, all within about a 7-10 day period. All confirmed, feared or believed to be the same issue. Stock exhaust valve failure. But do know, that if it were not happening, then there would likely be no discussion of it. One thread though?????, and you would wind up with perhaps thousands of posts in it, making it impossible to navigate.
(Post 1583822398)
Thanks, I found the option. I also appreciate the feedback. You would think there are a lot of variables but mostly all I see is 37 pages of insults and a few solutions peppered in.
Shame. :( There are two basic ways of handling this problem. 1. Stock valves, bronze guides. 2. Stainless steel valves, bronze guides. Pick an option based on what you have seen in terms of the reports in here, what cylinder head professionals and shops that you trust after you have had a chance to ask yourself just why you trust them, have to say, and go with the option you are comfortable with. No need for a new poll. |
Originally Posted by '06 Quicksilver Z06
(Post 1583822468)
The discussion of this matter will continue for as long as it continues to happen.
There is no abating the discussion of it. As it increases in frequency, or potential instances of it increase in frequency, so will the discussion of it . Another potential one just about an hour ago. http://forums.corvetteforum.com/c6-z...r-exhaust.html This new one to go along with the one from Bill Dearborn, 1 Bad Burb, Cantevendrive78, all within about a 7-10 day period. All confirmed, feared or believed to be the same issue. Stock exhaust valve failure. But do know, that if it were not happening, then there would likely be no discussion of it. One thread though?????, and you would wind up with perhaps thousands of posts in it, making it impossible to navigate. Not sure what you are looking for my friend. There are two basic ways of handling this problem. 1. Stock valves, bronze guides. 2. Stainless steel valves, bronze guides. Pick an option based on what you have seen in terms of the reports in here, what cylinder head professionals and shops that you trust after you have had a chance to ask yourself just why you trust them, have to say, and go with the option you are comfortable with. No need for a new poll. Thank you for proving my point. Either that or you missed my point. :rofl: Also quite honestly Quick. I see the same 5-10 people posting about it. Sure new threads come up and they should be consolidated. Lots of other reasons to own the Z06 and reading threads on this forum was my point. |
(Post 1583822322)
Originally Posted by JWingo
(Post 1583822833)
Consolidation would be good. Too much clutter.
Quick, I like you bro, but how can you say that is productive? Also its what every single thread about this issue turns into with the same participants. The next drama the next drama thread: http://forums.corvetteforum.com/c6-z...est-video.html This one too: http://forums.corvetteforum.com/c6-z...r-exhaust.html Both will turn into 10+ pages of pissing match over the same crap with no new data. That is my point Quick. |
(Post 1583822876)
Too much BS quite honestly. Look at that other valve thread. A pissing match for the last 7 pages.
Originally Posted by z0sicktanner
(Post 1583822943)
it's just now starting to get rolling. the failure rates are gonna go up. I agree with you. but when ppl lose a 15k engine some will be pissed and make their own thread I would
2. Why must a holed block result in a $15K engine? Seriously, wouldn't a bare block and a rebuild with salvaged parts be an option? For sure you'd need: bare block, couple of valves, one bare cylinder head, one piston, probably a piston pin and maybe a rod. Plus all the consumables (gaskets, bearings, bushings, seals, etc). Crank should survive, shouldn't it? Some stuff you probably couldn't clean the debris out of and should replace to be on the safe side: oil lines for sure, intake manifold maybe, cats maybe. I have to be overlooking something? |
(Post 1583822943)
2. Very rarely do you see the person who creates the thread in more than two to three posts on that thread. The other 600 replies are the bickering and pissing match trying to figure out who what where when and why and who works where and can debate better and who is more right and who works for GM.... ect ect.. lol you get my point. |
(Post 1583822876)
Quick, I like you bro, but how can you say that is productive? Also its what every single thread about this issue turns into with the same participants. The next drama the next drama thread: http://forums.corvetteforum.com/c6-z...est-video.html This one too: http://forums.corvetteforum.com/c6-z...r-exhaust.html Both will turn into 10+ pages of pissing match over the same crap with no new data. That is my point Quick. What exactly are you looking to do here propain? I'm curious. Because if it is to make one big thread, that nobody will be able to find anything in it. Besides, my point was, the options for management of this matter, which is really all that is left to discuss about it, as there is no longer any question as to if it exist, have already been discussed, and that was outlined in one of those two options. |
(Post 1583823135)
I'm curious. Because if it is to make one big thread, that nobody will be able to find anything in. Besides, my point was, the options for management of this matter, which is really all that is left to discuss about it, as there is no longer any question as to if it exist, have already been discussed, and that was outlined in one of those two options. Clean up the BS on this forum. Sorry, just cranky watching a good thread turn into a pissing match between you and Mark for the last 3 days and got me to this point. What can be found in that wonderfully productive thread anyhow that can't be found in the 87 page sticky above about the "Official GM response" I can answer that, nothing we haven't read before. So why the need to pollute every single thread with it? A consolidated thread discussing the topic would be better. Why must every thread turn into a 20 page pissing match? Quite honestly its turning a good forum into a sewing circle. I'm sure many have either choose to ignore it or not come here anymore because of it. Someone posts that their car blew up: "Sorry, that sucks, we feel your pain, Check out this sticky for the info you are looking for" Seems pretty straightforward to me. But hey.... fight the good fight if you must in every thread. Seems exhausting to me and I don't know how you haven't tired of it yet. :thumbs: |
Step 1 attack posters with experience and information in valve threads.
Step 2 complain about bickering within the valve threads. Step 3 congratulate yourself on mastering the interweb. |
Originally Posted by Mark200X
(Post 1583823009)
1. Agree on the consolidation, OP. Or a sub-forum.
(Post 1583823203)
What can be found in that wonderfully productive thread anyhow that can't be found in the 87 page sticky above about the "Official GM response" I can answer that, nothing we haven't read before. So why the need to pollute every single thread with it? A consolidated thread discussing the topic would be better. Why must every thread turn into a 20 page pissing match? Quite honestly its turning a good forum into a sewing circle. I'm sure many have either choose to ignore it or not come here anymore because of it. Someone posts that their car blew up: "Sorry, that sucks, we feel your pain, Check out this sticky for the info you are looking for" Seems pretty straightforward to me. But hey.... fight the good fight if you must in every thread. Seems exhausting to me and I don't know how you haven't tired of it yet. :thumbs: And what information would the sticky contain? Thanks |
Originally Posted by jedblanks
(Post 1583823210)
(Post 1583823031)
1. Agreed. That will happen as these older cars get more miles on them.
Originally Posted by ramairws6
(Post 1583823361)
I have seen 3 engines destroyed by exhaust valves first hand. Out of 3 of them all 3 had the crank destroyed. [...]
Okay, thanks for the info :cheers: |
(Post 1583823393)
I think I understand what you mean.
And what information would the sticky contain? Thanks I think a good first post with everything we know including statements from reputable shops and their recommended fixes. |
