Originally Posted by 240sx2jz
(Post 1583787264)
I realize you are trying to stir the pot and state there is always going to be "some wear" because i chose my words poorly when i stated "no wear" but in comparison to the other valves i have seen there is a night and day difference. valves running in worn guides have a large tapering section of coked oil on them, ones that have a crisp line showing the seating position of the stem in the guide can be seen as performing under the design intent. Any motorcycle valves/car valves i have seen have displayed this when working properly.
I communicated with the person who had the heads and was reworking them. he stated the guides were all within spec at 24k of primarily tracked miles. It is impossible for us to know what valve was in what guide because the owner disassembled the heads himself. But i can tell you all but two of the valves had very crisp carbon lines on them, the broken one looked very clean as well. Nothing compared to what my valves looked like. I sent an email to the guy with the heads to see if he still has the data, so fingers crossed. |
(Post 1583787264)
I realize you are trying to stir the pot and state there is always going to be "some wear" because i chose my words poorly when i stated "no wear" but in comparison to the other valves i have seen there is a night and day difference. valves running in worn guides have a large tapering section of coked oil on them, ones that have a crisp line showing the seating position of the stem in the guide can be seen as performing under the design intent. Any motorcycle valves/car valves i have seen have displayed this when working properly. [...]
(Post 1583784824)
lets not forget.......I have a valve stem sitting on my desk with no signs of guide wear, yet it is still missing a head. [...]
a) you have a broken valve with no signs of wear (coking, whatever) on the stem, or b) you have a broken valve that came out of a guide known to have no guide wear? |
I can post a wiggle text on 505's head if need be. when he shipped me the head they had some things on them that only 505 would know. to rockers had the tips cut off and the rockers bolts rounded off in two rocker arms. the two rockers are still on the head.
Originally Posted by '06 Quicksilver Z06
(Post 1583786637)
But if you want to believe that the only way one of these stock valves can snap a head off and fail, is if the guide it is in is grossly out of spec, and at a time when no one has the specs on all guides which had a valve fail inside of them, well then go ahead.
How far do your guides have to be out of spec for one to fail? Has anyone actually consistently shown just how far your guides have to be out of spec for one of the stock valves to snap off and window your block? You feel lucky? ;). Anybody else? Would folks agree that 9 out of 10 cars on this forum have guides out of spec when measured? Why then, aren't we seeing 9 out of 10 cars fail valves, and 1 out of 10 cars have guides out of spec? There are the additional factors supporting my personal take here, like Katech's 100% track record using OEM valves in customer motors that cost $40,000+. The employees there put a roof over their head and food on the table for their families by selling LS7s, if they really saw an issue with the valve rather than just the guide, they would not use it. Plus, any WCCH head with bronze guide and OEM valves has proven 100% successful as well. If that's a sample of 50 and SS is a sample of 220, they are both small I admit, but they are successes thus far nonetheless. So that sample of 270 no longer having factory guides regardless of valve type has a 100% success rate in my opinion. I don't know what the tolerances are as far as how out of spec guides can be where the oem valve still survives. Hoefi had some great insight here, maybe he can chime in. I say the OEM spec limit for guides is the limit, because I haven't observed any data point to counter this. No doubt a SS valve will fare better with an out of spec guide causing repeated off-centered head hits and stem wear. But that isn't the discussion. The question is (at least for me), why is it necessary when I only see failures on out of spec guides, and why is the guide failing so often? The machining theory for all years (not limited to 09s /10s etc) is the only one I can't poke a hole in with the data. Again, my theory/perspective here, want to make that clear. |
Originally Posted by ConfusedGarage
(Post 1583788086)
No sir, I do not believe a failed guide is the only way a valve fails. I believe it is the most common cause from how I interpret the data we have available. At some point in a modest volume car I know that an OEM will have a failure of just about every part of their car; water pumps, trans, door handles, radios, ac, you name it...and there will be a valve failure. That would be pretty ignorant for anyone to think along those lines.
Would folks agree that 9 out of 10 cars on this forum have guides out of spec when measured? Why then, aren't we seeing 9 out of 10 cars fail valves, and 1 out of 10 cars have guides out of spec? There are the additional factors supporting my personal take here, like Katech's 100% track record using OEM valves in customer motors that cost $40,000+. The employees there put a roof over their head and food on the table for their families by selling LS7s, if they really saw an issue with the valve rather than just the guide, they would not use it. Plus, any WCCH head with bronze guide and OEM valves has proven 100% successful as well. If that's a sample of 50 and SS is a sample of 220, they are both small I admit, but they are successes thus far nonetheless. So that sample of 270 no longer having factory guides regardless of valve type has a 100% success rate in my opinion. I don't know what the tolerances are as far as how out of spec guides can be where the oem valve still survives. Hoefi had some great insight here, maybe he can chime in. I say the OEM spec limit for guides is the limit, because I haven't observed any data point to counter this. No doubt a SS valve will fare better with an out of spec guide causing repeated off-centered head hits and stem wear. But that isn't the discussion. The question is (at least for me), why is it necessary when I only see failures on out of spec guides, and is the guide failing so often? The machining theory for all years (not limited to 09s /10s etc) is the only one I can't poke a hole in with the data. Again, my theory/perspective here, want to make that clear. |
Originally Posted by ramairws6
(Post 1583788108)
Sorry, but your part in bold is incorrect. Katech DOES NOT have 100% track record with the stock exhaust valves as you say :smash:
(Post 1583788086)
Would folks agree that 9 out of 10 cars on this forum have guides out of spec when measured? Why then, aren't we seeing 9 out of 10 cars fail valves, and 1 out of 10 cars have guides out of spec? There are the additional factors supporting my personal take here, like Katech's 100% track record using OEM valves in customer motors that cost $40,000+. The employees there put a roof over their head and food on the table for their families by selling LS7s, if they really saw an issue with the valve rather than just the guide, they would not use it. Plus, any WCCH head with bronze guide and OEM valves has proven 100% successful as well. If that's a sample of 50 and SS is a sample of 220, they are both small I admit, but they are successes thus far nonetheless. So that sample of 270 no longer having factory guides regardless of valve type has a 100% success rate in my opinion. I don't know what the tolerances are as far as how out of spec guides can be where the oem valve still survives. Hoefi had some great insight here, maybe he can chime in. I say the OEM spec limit for guides is the limit, because I haven't observed any data point to counter this. No doubt a SS valve will fare better with an out of spec guide causing repeated off-centered head hits and stem wear. But that isn't the discussion. The question is (at least for me), why is it necessary when I only see failures on out of spec guides, and is the guide failing so often? The machining theory for all years (not limited to 09s /10s etc) is the only one I can't poke a hole in with the data. Again, my theory/perspective here, want to make that clear. As usuual I read your posts with great interest my friend. First because they are well thought out, well written, and you tend to make several good points in each post you write. Finally, even though you and I have gone different routes in the management of this matter, I have the utmost respect for you, in that you have consistently put your money where you mouth is. You, (and a few others for that matter) believe in your method and are willing to put it to the test, and under penalty of possible failure and out of pocket expense. It is difficult for me to describe how much I respect that. That is considerably more than I can say for some of the other folk in here, and what extent they have gone to. Or not. So in light of that, here are my thoughts on what you just said. I mentioned earlier that people refer to mine, as the "shotgun" approach, and I am not offended by this moniker, because they are not too far off in that opinion. People HAVE had success just doing the guides and keeping the stock valves. I won't sit here and try and deny the obvious and easily verifiable, because there is no denying it, and my credibility in here, means something to me. I would point out, that by changing to a more durable solid stainless steel valve, that I am addressing another potential failure point. And should my guides, someday find their way out of spec, that I have a bit more "forgiveness" in terms of the potential for ultimately a valve failure. If I can do this, with no practical, perceivable or consistently measurable performance or street penalty, well then it is worth it to me to have that added insurance. It boils down to this ConfusedGarage. For me, knowing that the stock valves well could be one of the "root causes" or "major players" in this matter, it is just not worth the risk of my running the stock valves, if the penalty for getting rid of them is not going to be severe. And so far, and since late 2005 when LG Motorsports first started using these valves in stock LS7 heads, it has not. |
:iagree::thumbs:
Originally Posted by Mark200X
(Post 1583781978)
Well, I don't think it's going to be for pinks, but if he tries to pass me on the outside I'm gonna put him in the wall :rock:
Originally Posted by Vette @ 71
(Post 1583788169)
You refer to the one in Germany?? Shame on you ...
Originally Posted by 1 BAD BURB
(Post 1583787541)
In case all of you were wondering what the engine looks like. This is the motor in discussion here. Came out of my 07 z06. Owner was supposedly tracking it and was at 120mph when it went
Just trying to understand the circumstances as this is 'your Z06' but the 'owner' was tracking it. |
Originally Posted by Jawnathin
(Post 1583788506)
For clarity, you bought the car with the engine already destroyed? Or did you sell the motor?
(Post 1583788506)
Thanks. I figured it was something like that, but wanted to understand the story with a little more clarity.
(Post 1583788575)
He bought it with the engine down already...
Some poor bastard had to sell this car as a roller because of a dropped valve. The bath he must have taken. And yet we have folks in here, with no experience in this matter, and never having reached redline in their own cars, telling us how it ought be managed, and feeling that what they have to say on this issue, ought even be listened to. |
I think you sent that to my old account I'm the one with his head
(Post 1583787671)
I didn't understand what you said:
So let me try again: a) you have a broken valve with no signs of wear (coking, whatever) on the stem, or b) you have a broken valve that came out of a guide known to have no guide wear? b) i haven't measured the guides myself, "z0sick" stated the guides were all in spec. looking at the stems i would have deducted this same conclusion without measuring them. |
(Post 1583789048)
Yup i couldnt remember what the original screen name was haha. Can send a link to the sheet you posted up?? do you still have the head??
a) yes i have a valve from the heads that "z0sicktanner" has stated the guides were in spec. The valve that is missing the head has zero coking of oil above the seat line b) i haven't measured the guides myself, "z0sick" stated the guides were all in spec. looking at the stems i would have deducted this same conclusion without measuring them. |
(Post 1583788762)
Damn.
(Post 1583788762)
Damn.
(Post 1583789048)
[...] a) yes i have a valve from the heads that "z0sicktanner" has stated the guides were in spec. The valve that is missing the head has zero coking of oil above the seat line
b) i haven't measured the guides myself, "z0sick" stated the guides were all in spec. looking at the stems i would have deducted this same conclusion without measuring them. As to the bold portion in b), I wouldn't consider that wise but it's a free country ;)
(Post 1583787264)
[...] valves running in worn guides have a large tapering section of coked oil on them, ones that have a crisp line showing the seating position of the stem in the guide can be seen as performing under the design intent. [...]
One of the rougher stems after a bit of cleanup:
Originally Posted by Mark200X, in another thread
(Post 1583148807)
[...] clearly some galling was going on. The following is one of the used valves after it spent 10 hours in a vibratory tumbler in an attempt to clean it up (only slightly successful). [...]:
This is the same valve before cleanup:
Originally Posted by Mark200X, in the same thread
(Post 1583139851)
