parking brake on a C4
So does this brake pull in all 4 brakes, when applied? Dont rip me too bad, new C4 owner here. And yea i did read the owners manual, on how to apply brake. But it was different than what my dealer told me.....:ack:
It pulls on two small drum type shoes in each wheel on the rear only. They're mounted on the inward part of the rear discs.
Originally Posted by 65GGvert
(Post 1583729026)
They're mounted on the inward part of the rear discs. Early cars had separate park brakes inside the rotor Late cars used the rear calipers as the park brakes |
huh, so even tho you apply the pedal, which hits all 4 brakes, then work the lever, it only pulls in a cable to hold the rears in? I cant imagine that it has seperate park brakes on the rotor, since you apply the pedal first, then pull the lever.
Originally Posted by MikeT 90 C4sixer
(Post 1583729354)
Modern automobiles have hydraulic braking systems. But the parking brake still relies on a cable actuated brake separate from the main braking system. I believe some of the newer cars are going to an electrically actuated parking brake system though. |
The parking brake is mechanical and cable driven, partly so that when you set the brake and walk away and fluid leaks out, or hose leaks, or m/c fails, etc the brake will still be on and your car won't roll away.
Originally Posted by RollaMo-LT4
(Post 1583729502)
Pretty much all vehicle parking brakes work like that.
Modern automobiles have hydraulic braking systems. But the parking brake still relies on a cable actuated brake separate from the main braking system. But on my '90C4, manual says to push the main brake pedal down, then pull lever on left side up hard, then just let it go down easy. Exit the car. To release, put foot on pedal, pull lever, push button let go slowly. Granted, i have not pulled a wheel yet on this car, to visually look at what i got. Good discussion, tho1 |
(Post 1583730015)
Understand that. My GMC truck has a seperate pedal i push down hard, and applies mechanical brake drums installed on the inside of the rear disc rotors. My little cavalier has a hand brake lever, in center of console, that applies the cable to rear drum brakes.
The earlier cars have a drum brake inside the rear rotors.
Later cars have a lever that presses against the back of the caliper pad. That's why they tell you to step on the brake pedal and then pull up the brake lever. The brake lever by itself doesn't have enough leverage to apply the brake firmly enough to hold the car. |
(Post 1583729354)
The C5's and later have a similar internal rotor / drum park setup http://i171.photobucket.com/albums/u...Diff/early.jpg |
Originally Posted by Cliff Harris
(Post 1583730562)
