Corvette Z06 Package 2006-2012 Rotor Slotted Front & Rear Set T3 Design Hawk HP Plus
Corvette Z06 Package 2006-2012 Rotor Slotted Front & Rear Set T3 Design Hawk HP Plus http://www.xplosiveperformance.com/t...axx=300&maxy=0 http://www.xplosiveperformance.com/t...axx=300&maxy=0 DBA Brake Rotors - 4000 Series: DBA 4000 Series Rotors are a mid-series enhanced performance rotor. These rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. Suitable for specific production car motorsport use. Patented ‘Kangaroo Paw’ ventilation design* provides greater heat dissipation Tri-Symmetrical T3 Slot design dampens the vibration harmonics resulting in a quieter, responsive and a further improvement of brake pedal feel when compared to the T2 slot design XG150 High Carbon Alloyed Iron increases the thermal capacity properties of the rotor TSP (Thermal Stability Profiling) prolongs the service life of the rotor. This process is only applied to HEAVY DUTY, T3 4X4 and CLUBSPEC rotors containing XG-150 high carbon alloyed iron Protection paint on hub and non friction surfaces Heat paint markings change colour to monitor peak braking temperatures Take full advantage of your stoppers with these DBA Club Spec 4000 T3 brake rotors. These rotors are full of features desired by the track enthusiast and weekend cruiser alike. DBA's exclusive XG150 high-carbon alloyed iron and TSP process allows these rotors to withstand extreme heat without the serious degradation found in other, lesser rotors. DBA's patented Kangaroo Paw ventilation provides awesome heat dissipation, and their T3 slot design dampens vibration for quiet, responsive braking and pedal feel. To keep these rotors looking as great as they perform, DBA applies a protective paint onto the non-friction areas, along with heat paint marks, so you can monitor peak breaking temperatures. Reign in all of that speed safely with these DBA Club Spec 4000 T3 brake rotors. Package Includes: (2) Front T3 Club Spec Slotted 4000 Series Rotors (2) Rear T3 Club Spec Slotted 4000 Series Rotors (1) Set Hawk HP Plus One Piece Front Pads (1) Set Hawk HP Plus One Piece Rear Pads On sale: $1,096.25 Free Shipping Lower US |
Corvette Z06 Package 2006-2012 Rotor Slotted Front & Rear Set T3 Design Hawk HP Plus http://www.xplosiveperformance.com/t...axx=300&maxy=0 DBA Brake Rotors - 4000 Series: DBA 4000 Series Rotors are a mid-series enhanced performance rotor. These rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. Suitable for specific production car motorsport use. Patented ‘Kangaroo Paw’ ventilation design* provides greater heat dissipation Tri-Symmetrical T3 Slot design dampens the vibration harmonics resulting in a quieter, responsive and a further improvement of brake pedal feel when compared to the T2 slot design XG150 High Carbon Alloyed Iron increases the thermal capacity properties of the rotor TSP (Thermal Stability Profiling) prolongs the service life of the rotor. This process is only applied to HEAVY DUTY, T3 4X4 and CLUBSPEC rotors containing XG-150 high carbon alloyed iron Protection paint on hub and non friction surfaces Heat paint markings change colour to monitor peak braking temperatures Take full advantage of your stoppers with these DBA Club Spec 4000 T3 brake rotors. These rotors are full of features desired by the track enthusiast and weekend cruiser alike. DBA's exclusive XG150 high-carbon alloyed iron and TSP process allows these rotors to withstand extreme heat without the serious degradation found in other, lesser rotors. DBA's patented Kangaroo Paw ventilation provides awesome heat dissipation, and their T3 slot design dampens vibration for quiet, responsive braking and pedal feel. To keep these rotors looking as great as they perform, DBA applies a protective paint onto the non-friction areas, along with heat paint marks, so you can monitor peak breaking temperatures. Reign in all of that speed safely with these DBA Club Spec 4000 T3 brake rotors. Package Includes: (2) Front T3 Club Spec Slotted 4000 Series Rotors (2) Rear T3 Club Spec Slotted 4000 Series Rotors (1) Set Hawk HP Plus One Piece Front Pads (1) Set Hawk HP Plus One Piece Rear Pads On sale: $1,096.25 Free Shipping Lower US |
This would be a great deal if your website worked:(
Originally Posted by okiedude
(Post 1583708976)
Thanks |
Corvette Z06 Package 2006-2012 Rotor Slotted Front & Rear Set T3 Design Hawk HP Plus DBA Club Spec 4000 T3 brake rotors. http://www.xplosiveperformance.com/t...axx=300&maxy=0 DBA Brake Rotors - 4000 Series: DBA 4000 Series Rotors are a mid-series enhanced performance rotor. These rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. Suitable for specific production car motorsport use. Patented ‘Kangaroo Paw’ ventilation design* provides greater heat dissipation Tri-Symmetrical T3 Slot design dampens the vibration harmonics resulting in a quieter, responsive and a further improvement of brake pedal feel when compared to the T2 slot design XG150 High Carbon Alloyed Iron increases the thermal capacity properties of the rotor TSP (Thermal Stability Profiling) prolongs the service life of the rotor. This process is only applied to HEAVY DUTY, T3 4X4 and CLUBSPEC rotors containing XG-150 high carbon alloyed iron Protection paint on hub and non friction surfaces Heat paint markings change colour to monitor peak braking temperatures Take full advantage of your stoppers with these DBA Club Spec 4000 T3 brake rotors. These rotors are full of features desired by the track enthusiast and weekend cruiser alike. DBA's exclusive XG150 high-carbon alloyed iron and TSP process allows these rotors to withstand extreme heat without the serious degradation found in other, lesser rotors. DBA's patented Kangaroo Paw ventilation provides awesome heat dissipation, and their T3 slot design dampens vibration for quiet, responsive braking and pedal feel. To keep these rotors looking as great as they perform, DBA applies a protective paint onto the non-friction areas, along with heat paint marks, so you can monitor peak breaking temperatures. Reign in all of that speed safely with these DBA Club Spec 4000 T3 brake rotors. Package Includes: (2) Front T3 Club Spec Slotted 4000 Series Rotors (2) Rear T3 Club Spec Slotted 4000 Series Rotors (1) Set Hawk HP Plus One Piece Front Pads (1) Set Hawk HP Plus One Piece Rear Pads http://www.xplosiveperformance.com/C...ds_p_3402.html On sale: $1,096.25 Free Shipping Lower US |
Originally Posted by Xplosive Performance
(Post 1583709523)
Sorry not sure what happen it been working please try it now or we can send you a paypal invoice or the phones have calmed down now try 888.493.8041
Thanks |
Thank you for the kind words we do try our hardest to fulfill your high performance requirements your rotors will be delivered on Friday again thank you
Corvette Z06 Package 2006-2012 Rotor Slotted Front & Rear Set T3 Design Hawk HP Plus DBA Club Spec 4000 T3 brake rotors. http://www.xplosiveperformance.com/t...axx=300&maxy=0 http://www.xplosiveperformance.com/t...axx=300&maxy=0 DBA Brake Rotors - 4000 Series: DBA 4000 Series Rotors are a mid-series enhanced performance rotor. These rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. Suitable for specific production car motorsport use. Patented ‘Kangaroo Paw’ ventilation design* provides greater heat dissipation Tri-Symmetrical T3 Slot design dampens the vibration harmonics resulting in a quieter, responsive and a further improvement of brake pedal feel when compared to the T2 slot design XG150 High Carbon Alloyed Iron increases the thermal capacity properties of the rotor TSP (Thermal Stability Profiling) prolongs the service life of the rotor. This process is only applied to HEAVY DUTY, T3 4X4 and CLUBSPEC rotors containing XG-150 high carbon alloyed iron Protection paint on hub and non friction surfaces Heat paint markings change colour to monitor peak braking temperatures Take full advantage of your stoppers with these DBA Club Spec 4000 T3 brake rotors. These rotors are full of features desired by the track enthusiast and weekend cruiser alike. DBA's exclusive XG150 high-carbon alloyed iron and TSP process allows these rotors to withstand extreme heat without the serious degradation found in other, lesser rotors. DBA's patented Kangaroo Paw ventilation provides awesome heat dissipation, and their T3 slot design dampens vibration for quiet, responsive braking and pedal feel. To keep these rotors looking as great as they perform, DBA applies a protective paint onto the non-friction areas, along with heat paint marks, so you can monitor peak breaking temperatures. Reign in all of that speed safely with these DBA Club Spec 4000 T3 brake rotors. Package Includes: (2) Front T3 Club Spec Slotted 4000 Series Rotors (2) Rear T3 Club Spec Slotted 4000 Series Rotors (1) Set Hawk HP Plus One Piece Front Pads (1) Set Hawk HP Plus One Piece Rear Pads http://www.xplosiveperformance.com/C...ds_p_3402.html On sale: $1,096.25 Free Shipping Lower US |
Corvette Z06 Package 2006-2012 Rotor Slotted Front & Rear Set T3 Design Hawk HP Plus http://www.xplosiveperformance.com/t...axx=300&maxy=0 http://www.xplosiveperformance.com/t...axx=300&maxy=0 DBA Brake Rotors - 4000 Series: DBA 4000 Series Rotors are a mid-series enhanced performance rotor. These rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. Suitable for specific production car motorsport use. Patented ‘Kangaroo Paw’ ventilation design* provides greater heat dissipation Tri-Symmetrical T3 Slot design dampens the vibration harmonics resulting in a quieter, responsive and a further improvement of brake pedal feel when compared to the T2 slot design XG150 High Carbon Alloyed Iron increases the thermal capacity properties of the rotor TSP (Thermal Stability Profiling) prolongs the service life of the rotor. This process is only applied to HEAVY DUTY, T3 4X4 and CLUBSPEC rotors containing XG-150 high carbon alloyed iron Protection paint on hub and non friction surfaces Heat paint markings change colour to monitor peak braking temperatures Take full advantage of your stoppers with these DBA Club Spec 4000 T3 brake rotors. These rotors are full of features desired by the track enthusiast and weekend cruiser alike. DBA's exclusive XG150 high-carbon alloyed iron and TSP process allows these rotors to withstand extreme heat without the serious degradation found in other, lesser rotors. DBA's patented Kangaroo Paw ventilation provides awesome heat dissipation, and their T3 slot design dampens vibration for quiet, responsive braking and pedal feel. To keep these rotors looking as great as they perform, DBA applies a protective paint onto the non-friction areas, along with heat paint marks, so you can monitor peak breaking temperatures. Reign in all of that speed safely with these DBA Club Spec 4000 T3 brake rotors. Package Includes: (2) Front T3 Club Spec Slotted 4000 Series Rotors (2) Rear T3 Club Spec Slotted 4000 Series Rotors (1) Set Hawk HP Plus One Piece Front Pads (1) Set Hawk HP Plus One Piece Rear Pads On sale: $1,096.25 Free Shipping Lower US Call or PM for other pad options Ceramic, HPS, DTC70 |
dba 4000 series T3 Club Spec Rotors Corvette Z06 Package 2005-2012 Rotor Slotted Left/Right Front Set http://www.xplosiveperformance.com/t...axx=300&maxy=0http://www.xplosiveperformance.com/t...axx=300&maxy=0 Take full advantage of your stoppers with these DBA Club Spec 4000 T3 brake rotors. These rotors are full of features desired by the track enthusiast and weekend cruiser alike. DBA's exclusive XG150 high-carbon alloyed iron and TSP process allows these rotors to withstand extreme heat without the serious degradation found in other, lesser rotors. DBA's patented Kangaroo Paw ventilation provides awesome heat dissipation, and their T3 slot design dampens vibration for quiet, responsive braking and pedal feel. To keep these rotors looking as great as they perform, DBA applies a protective paint onto the non-friction areas, along with heat paint marks, so you can monitor peak breaking temperatures. Reign in all of that speed safely with these DBA Club Spec 4000 T3 brake rotors. Patented ‘Kangaroo Paw’ ventilation design* provides greater heat dissipation Tri-Symmetrical T3 Slot design dampens the vibration harmonics resulting in a quieter, responsive and a further improvement of brake pedal feel when compared to the T2 slot design XG150 High Carbon Alloyed Iron increases the thermal capacity properties of the rotor TSP (Thermal Stability Profiling) prolongs the service life of the rotor. This process is only applied to HEAVY DUTY, T3 4X4 and CLUBSPEC rotors containing XG-150 high carbon alloyed iron Protection paint on hub and non friction surfaces Heat paint markings change colour to monitor peak braking temperatures http://www.xplosiveperformance.com/C...et_p_2406.html Front Package Kit includes (2) Rotors Front Right Front Left $391.68 Free Shipping Lower USA Corvette C6 - Z06 Package 2005-2012 Rotor Slotted Left/Right Rear Set http://www.xplosiveperformance.com/C...t-_p_2407.html Rear Package Kit includes (2) Rotors Rear Right Rear Left $391.68 Free Shipping Lower USA Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Front Set w/Hawk Ceramic Pads http://www.xplosiveperformance.com/C...ds_p_2441.html $584.68 Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Front Set w/Hawk HP Plus brake pads http://www.xplosiveperformance.com/C...ds_p_2438.html $624.68 Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Rear Set w/Hawk Ceramic Pads http://www.xplosiveperformance.com/C...ds_p_2440.html $541.68 PADS ONLY 2005-12 Z06 & GS Hawk HP Plus Pads -Front- New 1 piece pads (4/set) http://www.xplosiveperformance.com/2...t-_p_2433.html $233.00 2005-12 Z06 & GS Hawk DTC-70 Race Pads -Front- New 1 piece pads (4/set) http://www.xplosiveperformance.com/2...t-_p_2565.html $299.99 2005-12 Z06 & GS Hawk Ceramic Pads - Front - New 1 piece pads (4/set) $193.00 http://www.xplosiveperformance.com/2...et_p_2430.html 2005-12 Z06 & GS Hawk Ceramic Pads - Rear - New 1 piece pads (4/set) $147.98 http://www.xplosiveperformance.com/2...t-_p_2431.html 06-12 Corvette Z06 HPS Street Front Brake Pads 1 pcs (4/set) $187.00 http://www.xplosiveperformance.com/0...et_p_3146.html 06-12 Corvette Z06 HPS Street Rear Brake Pads 1 pcs (4/set) $159.38 http://www.xplosiveperformance.com/0...et_p_3147.html 2005-12 Z06 & GS Hawk DTC-60 Race Pads -Rear- New 1 piece pads (4/set) $256.60 http://www.xplosiveperformance.com/2...t-_p_2614.html C6/ZO6 Slotted Rotors & Hawk Brake Pad Packages 06-12 Corvette Z06 Street Package (4) StopTech Rotors Hawk Ceramic Front & Rear 1 piece pads Package Contains: (1) StopTech Gas Slotted Front Left one piece Rotor (1) StopTech Gas Slotted Front Right one piece Rotor (1) StopTech Gas Slotted Rear Left one piece Rotor (1) StopTech Gas Slotted Rear Right one piece Rotor (1) Set Hawk Ceramic Front 1 piece brake pads (1) Set Hawk Ceramic Rear 1 piece brake pads http://www.xplosiveperformance.com/0...ds_p_3191.html $707.10 delivered Lower US 06-12 Corvette Z06 Street Package (4) StopTech Rotors Hawk HPS Pads Front & Rear 1 piece pads Package Contains: (1) StopTech Gas Slotted Front Left one piece Rotor (1) StopTech Gas Slotted Front Right one piece Rotor (1) StopTech Gas Slotted Rear Left one piece Rotor (1) StopTech Gas Slotted Rear Right one piece Rotor (1) Set Hawk High Performance Street (HPS) Front 1 piece brake pads (1) Set Hawk High Performance Street (HPS) Rear 1 piece brake pads http://www.xplosiveperformance.com/0...s-_p_3192.html $707.10 delivered Lower US 06-12 Corvette Z06 Street/HPDE Track Package (4) StopTech Rotors Hawk HP Plus Pads Front & Rear 1 piece pads Package Contains: (1) StopTech Gas Slotted Front Left one piece Rotor (1) StopTech Gas Slotted Front Right one piece Rotor (1) StopTech Gas Slotted Rear Left one piece Rotor (1) StopTech Gas Slotted Rear Right one piece Rotor (1) Set Hawk HP Plus Front 1 piece brake pads (1) Set Hawk HP Plus Rear 1 piece brake pads http://www.xplosiveperformance.com/0...s-_p_3193.html $756.95 delivered Lower US 06-12 Corvette Z06 HPDE & Race Track Package (4) StopTech Rotors Hawk DTC 70/60 Front & Rear 1 piece pads Package Contains: (1) StopTech Gas Slotted Front Left one piece Rotor (1) StopTech Gas Slotted Front Right one piece Rotor (1) StopTech Gas Slotted Rear Left one piece Rotor (1) StopTech Gas Slotted Rear Right one piece Rotor (1) Set Hawk DTC 70 Front 1 piece brake pads (1) Set Hawk DTC 60 Rear 1 piece brake pads http://www.xplosiveperformance.com/0...s-_p_3194.html $959.95 delivered Lower US 05-12 Corvette C6 Base Street Package (4) StopTech Rotors Hawk Ceramic Front & Rear Pads Package Contains: (1) StopTech Gas Slotted Front Left one piece Rotor (1) StopTech Gas Slotted Front Right one piece Rotor (1) StopTech Gas Slotted Rear Left one piece Rotor (1) StopTech Gas Slotted Rear Right one piece Rotor (1) Set Hawk Ceramic Front 1 piece brake pads (1) Set Hawk Ceramic Rear 1 piece brake pads http://www.xplosiveperformance.com/0...s-_p_3196.html $589.10 delivered Lower US 05-12 Corvette C6 Street Package (4) StopTech Rotors Hawk HPS Pads Front & Rear Pads Package Contains: (1) StopTech Gas Slotted Front Left one piece Rotor (1) StopTech Gas Slotted Front Right one piece Rotor (1) StopTech Gas Slotted Rear Left one piece Rotor (1) StopTech Gas Slotted Rear Right one piece Rotor (1) Set Hawk High Performance Street (HPS) Front 1 piece brake pads (1) Set Hawk High Performance Street (HPS) Rear 1 piece brake pads http://www.xplosiveperformance.com/0...ds_p_3197.html $589.10 delivered Lower US 05-12 Corvette C6 Street/HPDE Track Package (4) StopTech Rotors Hawk HP Plus Pads Front & Rear Pads Package Contains: (1) StopTech Gas Slotted Front Left one piece Rotor (1) StopTech Gas Slotted Front Right one piece Rotor (1) StopTech Gas Slotted Rear Left one piece Rotor (1) StopTech Gas Slotted Rear Right one piece Rotor (1) Set Hawk HP Plus Front 1 piece brake pads (1) Set Hawk HP Plus Rear 1 piece brake pads http://www.xplosiveperformance.com/0...ds_p_3198.html $634.10 delivered Lower US 05-12 Corvette C6 Base HPDE & Race Track Package (4) StopTech Rotors Hawk DTC 70/60 Front & Rear Pads Package Contains: (1) StopTech Gas Slotted Front Left one piece Rotor (1) StopTech Gas Slotted Front Right one piece Rotor (1) StopTech Gas Slotted Rear Left one piece Rotor (1) StopTech Gas Slotted Rear Right one piece Rotor (1) Set Hawk DTC 70 Front 1 piece brake pads (1) Set Hawk DTC 60 Rear 1 piece brake pads http://www.xplosiveperformance.com/0...s-_p_3195.html# $827.75 delivered Lower US Corvette Z06 Package 2006-2012 Rotor Slotted Front & Rear Set T3 Design Hawk HP Plus dba 4000 series T3 Club Spec Rotors http://www.xplosiveperformance.com/t...axx=300&maxy=0 http://www.xplosiveperformance.com/t...axx=300&maxy=0 DBA Brake Rotors - 4000 Series: DBA 4000 Series Rotors are a mid-series enhanced performance rotor. These rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. Suitable for specific production car motorsport use. Patented ‘Kangaroo Paw’ ventilation design* provides greater heat dissipation Tri-Symmetrical T3 Slot design dampens the vibration harmonics resulting in a quieter, responsive and a further improvement of brake pedal feel when compared to the T2 slot design XG150 High Carbon Alloyed Iron increases the thermal capacity properties of the rotor TSP (Thermal Stability Profiling) prolongs the service life of the rotor. This process is only applied to HEAVY DUTY, T3 4X4 and CLUBSPEC rotors containing XG-150 high carbon alloyed iron Protection paint on hub and non friction surfaces Heat paint markings change colour to monitor peak braking temperatures Take full advantage of your stoppers with these DBA Club Spec 4000 T3 brake rotors. These rotors are full of features desired by the track enthusiast and weekend cruiser alike. DBA's exclusive XG150 high-carbon alloyed iron and TSP process allows these rotors to withstand extreme heat without the serious degradation found in other, lesser rotors. DBA's patented Kangaroo Paw ventilation provides awesome heat dissipation, and their T3 slot design dampens vibration for quiet, responsive braking and pedal feel. To keep these rotors looking as great as they perform, DBA applies a protective paint onto the non-friction areas, along with heat paint marks, so you can monitor peak breaking temperatures. Reign in all of that speed safely with these DBA Club Spec 4000 T3 brake rotors. Package Includes: (2) Front T3 Club Spec Slotted 4000 Series Rotors (2) Rear T3 Club Spec Slotted 4000 Series Rotors (1) Set Hawk HP Plus One Piece Front Pads (1) Set Hawk HP Plus One Piece Rear Pads http://www.xplosiveperformance.com/C...ds_p_3402.html On sale: $1,096.25 Free Shipping Lower US |
