Originally Posted by newskatercat
(Post 1583662872)
Run Flats will have EMT on sidewall! :cheers:
Michelin runflats say ZP Firestone? Bridgestone? Pirelli? |
Ok, another question for the smartest Corvette people I know. My front tire states: 51 psi max pressure and my rear states: 45 psi max pressure but there is 30 psi in all 4 tires. Is that ok?
Originally Posted by Gearhead Jim
(Post 1583662897)
Goodyear runflats say EMT
Michelin runflats say ZP Firestone? Bridgestone? Pirelli? :willy: |
Originally Posted by ALLEN007
(Post 1583662948)
:thumbs: |
(Post 1583662844)
I appreciate all the great info.
I'm sure glad I didn't know they were not run flats before I went to Tampa the other day or I would probably have had a flat tire. Guess I better get me some Fix a Flat and a Nail Kit. |
Originally Posted by MakoShark72
(Post 1583662985)
Seriously??? I have driven for over 40 yrs and had ONE flat on the highway.. I think you were probably OK...:toetap:
Usually, but not always... http://forums.corvetteforum.com/c6-c...flat-tire.html |
Originally Posted by cclive
(Post 1583662974)
That is max only...proper cold pressure is shown on the doorjam sticker...30psi
:thumbs: The specification for your car is on the door (sometimes, older cars have the specification on the inside of the glovebox or console lid, or printed in the owner's manual). And it will almost always be way lower than the max tire pressure stamped on the sidewall of any tire. Just so you know.....:cheers: |
I appreciate the good info!
(Post 1583662160)
Only reason I mention it is that the traction control computer is looking for a particular ratio of revolutions per mile between the front and rear tires. If that ratio gets too far off from what is expected, then the computer will assume that some tire or tires is losing traction with the road. This can cause it to intervene and it will be very unexpected to the driver. I have never seen on the forum what the actual specification is, but if you are going to get new tires anyway, no reason not to get the OEM sizes to avoid possible problems.:thumbs:
(Post 1583662897)
Originally Posted by 50 4Ever
(Post 1583662970)
The GY Gen II Run Flats I had said ROF on the side - Run On Flat
:willy: Or does it mean "Rolling on Floor"? :D |
Bridgestone says RFT
(Post 1583660617)
What's bad about that is now that I know that I don't have run flats (thinking I did) and as loud as these tires are I can't imagine how loud run flats are.
A local autocross wizard had the original non-runflat PS2's on his Z51 car, then switched to runflat PS2's which he and his wife used to win the regional championships a few years ago. He told me there was no discernable difference in noise or ride between the two tires, and the runflats seemed to handle a little better.
The C5 Goodyear runflats certainly earned the name Runcraps, but newer designs are much better. |
:thumbs: Goodyear run flats where on my Vette when I purchased it they developed a bubble in the front tire so I switched to Firestone run flats smoother ride & less road noise!!
(Post 1583659663)
BF Goodrich G-Force T/A But to dark right now to see anything else. Thanks
http://i1205.photobucket.com/albums/...pse9647a76.jpg http://i1205.photobucket.com/albums/...psf0760218.jpg MT |
