Locked out of Corvette Battery Dead, How to OPEN FOB to reveal key?
I want to open the fob so i can get the physical key.
I have Corvette 2009. The FOB has a button at the bottom but it's a very thin and not very pressable button. i push it but it feels like i'm it doesn't go down at all. and i pull the thing at the bottom and nothing happens it's so hard. I read and saw a video where the guy does it with a FOB for his 2011 corvette but in that FOB, it was really easy to pull it out. Am i doing something wrong? Anyway what happened is the car battery seems dead so i can't open it with the wireless battery operated FOB even though we already replaced the FOB battery. Anyways, to pull the Physical key from the FOB, do i need some special tools or I'm too weak or something? I'm afriad to pull really hard cause it might break the fob. |
It is stiff at first. Press the button and pull on the silver part that holds the key. No tools required.
I believe there's some info in the owners manual for replacing the battery or else there is a sticky post.
Mine is an '08 so its probably the same. Yes, you do push in the tab / button near the metallic shiny base. Push it in to remove the key. And yes, it is pretty hard to push it in and pull out the key. I actually broke mine the day I brought it home from the Corvette Museum. To open the fob, after pulling the key out, I just used a knife inserted in the very thin opening down the sides to pry it open. I started closest to the open part (where the key used to be). It does feel like an ackward process. |
Originally Posted by CyberBullet
(Post 1583325693)
It feels liek the whole key fob is gonna break cause i'm pulling so hard. so i don't know what to do. |
Originally Posted by need-for-speed
(Post 1583325743)
Mine is an '08 so its probably the same. Yes, you do push in the tab / button near the metallic shiny base. Push it in to remove the key. And yes, it is pretty hard to push it in and pull out the key. I actually broke mine the day I brought it home from the Corvette Museum. To open the fob, after pulling the key out, I just used a knife inserted in the very thin opening down the sides to pry it open. I started closest to the open part (where the key used to be). It does feel like an ackward process. Interesting. great info!.. WHen i pull with al my might.. The side by where the key is(i can see tiny piece of metal ) is the side that separates at least a little opening. The other side doesn't separate at all. So i should try and insert something into the tiny opening and then work from there? I tried inserting a dime. Almost fits but not yet. it's still very tiny oepning |
1 Attachment(s)
1 Attachment(s)
So you're oepning the whole thing from the side? I thought i just had to remove the metal thing on the top by pulling it |
Chevy dave. Well i just want the key out. i'm not looking to get into the insides. I'm not looking to replace the battery of the keyfob. Had that done already.
I just want the key out. But you're saying since pulling it is almost impossible, that i should just open the whole thing like in your picture? |
1 Attachment(s)
Originally Posted by jodocV7
(Post 1583325803)
OHhhh
So you're oepning the whole thing from the side? I thought i just had to remove the metal thing on the top by pulling it then pull the silver out, i use a key ring to pull with, and if you have to , gently take pliers and squeeze the button in red.. Attachment 47720340 you can always open it up and get the key, seemed a little extreem but you can fyi... some say their key almost fall out on their own.. lol.. both you and i have to use the damn pliers to squeeze it to open it.. lol |
By the time we traded our 2006 (old style fob) for the 2009 (new style fob), I'd read all the threads here about how to remove the key. But when I tried to take it out for testing (a few don't work), it wouldn't come out.
Despite pressing hard on the release button, and using a spare key through the slot to get a better pull, it just wouldn't come out. Finally, brute force triumphed and it came out. But after doing that just a few times (I test it every year), the retention mechinism broke and the key wouldn't stay in the fob. So I bought a Fob Jacket (Google it) and that holds my key in place for now. Also allows me to slip a piece of stiff plastic inside the jacket to keep the various buttons from getting pressed by stuff in my pocket. I plan to get a new fob, just before my GMPP expires in another 50k miles. |
After you finally get the key out, take it and get it copied. The newer style fob is not very robust and you can't count on being able to remove the key from the fob on a regular basis...the mechanism is just not that good.:thumbs:
1 Attachment(s)
Originally Posted by Gearhead Jim
(Post 1583325980)
Despite pressing hard on the release button, and using a spare key through the slot to get a better pull, it just wouldn't come out. Finally, brute force triumphed and it came out. But after doing that just a few times (I test it every year), the retention mechinism broke and the key wouldn't stay in the fob. So I bought a Fob Jacket (Google it) and that holds my key in place for now. Also allows me to slip a piece of stiff plastic inside the jacket to keep the various buttons from getting pressed by stuff in my pocket. I plan to get a new fob, just before my GMPP expires in another 50k miles. Attachment 47720346 |
Good thought about the wife. Surprisingly, my wife's fob will release the key easily enough for her to do, but mine was the stubborn one. Go figure...
Originally Posted by cclive
(Post 1583326029)
And if you lock the fob in the hatch/trunk dead zone, it's a lifesaver to have a spare key in your wallet (or hidden on the car). Under $10 at most key shops. Tell 'em to use key blank B-106 (same as a Saturn). http://i381.photobucket.com/albums/o...s/IMG_0544.jpg http://i381.photobucket.com/albums/o...h_e8067bf0.jpghttp://i381.photobucket.com/albums/o...h_0af3d1c0.jpghttp://i381.photobucket.com/albums/o...h_8e166448.jpg I really like the fob covers. Cushions the fob from damage, not slippery, easier to find a bright color, different colors for different fob's. :thumbs: http://www.thejacketstore.com/servle...tte/Categories http://i381.photobucket.com/albums/o...h_18be6f97.jpg |
BTW, have you tried the hatch release button?
Maybe your battery still has enough juice that the button will work. http://i381.photobucket.com/albums/o...s/219c4032.jpg And no, you don't have to crawl thru the hatch. :willy: There's a pull-tab (on the left) that manually opens the driver's door. There's also a pull-tab for the fuel door. |
The tape over the keyhole is a very good idea that I have done also...highly recommended!
http://i381.photobucket.com/albums/o...s/219c4032.jpg:thumbs: |
i clean my key once in a while with WD 30, and also spray trunk lock....keeps all well..
Originally Posted by bud miller
(Post 1583327275)
I had a spare made and keep it on my key ring incase I lock the fob in the car or trunk. I am thinking about getting a spare fob and programming it to the car. Then take the battery out and hide it in the trunk. I think it will still work in the glove box without the battery. Then I could get home if I loose my fob.
